We cut another 4 cords for winter. As we were cutting I said " Should have a peavy"!
It's a Should have tool!
Absolutely a must have,you'll never do without one especially working alone,get a cant hook at least 60in with the log stand attachement,unbelievable tool. Logrite makes one that will last a lifetime,60,or 78in cant with log stand attachement check it out.I've moved 46 in red oak rounds green by myself with no wear and tear on back.I don't use one...cut about 30 cord the past 3 years without one.
That's the one to have ,I've got the Logrite 60" identical wouldn't be without it.I use this baby !
saves on chains and the back!
I am late jumping in. I used the Northern tool combo cant hook/log lift, 60" long, with steel and fiberglass handle to both roll and lift logs for many years. It is a very good cant hook; the handle is almost indestructible. (I broke a 3" wooden handle on a previous one by driving over it with a truck. That would not hurt the Northern handle a bit). However, I did bend the log lift foot lifting very heavy logs. So, I bought the Woodchuck Tools log lifter. It is lighter but can lift heavier logs, due to its shorter stand height, giving it more leverage. It also keeps the handle off the ground, and reduces the risk of crushing your hand under it when the log rolls onto the lift stand. So I now use the Woodchuck for bucking logs off the ground and the Northern for rolling them. I might remove the log lift stand from the Northern so I can get a larger arc of rotation when rolling. With the stand, it is limited to about 120 degrees. Without, it is close to 200 degrees.I don't use one...cut about 30 cord the past 3 years without one.
That Logrite sounds like a good tool. It sure is expensive, though.I had them both in my hands when I was shopping. The Logrite won as soon as I held it....I have a 60". Ideally, I would have a 48" as well.
If you only had one, would it be the 48" or 60"? The 60" sounds like it's for very big trees.
Spot on! After taking a 2 story trip down a elevator shaft without the elevator...Pulp hooks are great for certain jobs, but a pickaroon will do some of the same jobs without having to bend down.
