My quick searching I did not come across any 6T drivers. 7 T was fine with a 36” bar moving up to a full house 52” bar I think I could use the extra torque. Probably a switch to full skip chain will have more impact than a sprocket change.My g660 has a 7 tooth.
For tulip poplar, keeping the chain sharp, and being carful I was able to mill up a crotch that was 42” wide at the wide end. 25” at the narrow. It’s not ideal but I can get by. In total I have milled only 8 cuts and feel that I go my money’s worth out of it.I think a 660 is kinda small for a 52. Not having the outer clutch wouldn’t help either. I’d say for milling a 42 would be tops . At least for me
I feel for you not being able to get the new tool out. Can you at least get the saw out and run a few tanks through it? Added up and in total I have made only 12 milling cuts but that is about 15 tanks of fuel. Granted the smallest cut started at 22” and the biggest ended at 42”. I guess that I have about 25-30 tanks through it in total. I ran the first tank through it and never revved it up with out a load and then never wide open under load for more than 5-10 seconds. I can’t turn it over with out using the decomp button. You have to be way more manly than I am to to delete those.I am so excited. Looks like I will not be able to start milling til beginning of May.
Is that a 52” bar? If so,I didn’t know they made one that would fit the bar studs. It looks nice with no taper. My 72” cannon makes it hard to choke up on the mill without the chain making contactI feel for you not being able to get the new tool out. Can you at least get the saw out and run a few tanks through it? Added up and in total I have made only 12 milling cuts but that is about 15 tanks of fuel. Granted the smallest cut started at 22” and the biggest ended at 42”. I guess that I have about 25-30 tanks through it in total. I ran the first tank through it and never revved it up with out a load and then never wide open under load for more than 5-10 seconds. I can’t turn it over with out using the decomp button. You have to be way more manly than I am to to delete those.
In the mean time here’s what I got done yesterday. Will be bookshelves and porch swings by the end of the month. Staying super flat is not as important to me as getting it done soon. I did use paste wax as a finish last time and I really like that as a sealer to slow down drying butjust As important I don’t have to wait for it to dry. As for the greenness all around remember it was a hurricane took down this tree and made all of this possible for me. So you don’t need to be jealous.
Evan
View attachment 275165View attachment 275166
It is a 52”. its worked well so far. Chain tensioner is a weakness for the 660 at this length of bar. eBay with chain shipped for 230$. Mill was extended with t-slot aluminum. It would be nice to be make a shorter one for my 28” bar if I ever do dimensional lumber.Is that a 52” bar? If so,I didn’t know they made one that would fit the bar studs. It looks nice with no taper. My 72” cannon makes it hard to choke up on the mill without the chain making contact
Dang, that sucksThe 660 arrived sometime mid Jan. The idea was to run several tanks of gas through it bucking. Then tons of snow came and the bucking idea was out. I decided not to put any gas in it. Also, i have been out of the country since more less mid Jan and no idea when I will be back (damn covid). Hopefully mid April.
Huh, well, that’s good to know. I should probably get a smaller mill too. I had to replace a couple of the cheap adjustment studs after a while but not a big deal. Hard to get used to not sinching these down tightIt is a 52”. its worked well so far. Chain tensioner is a weakness for the 660 at this length of bar. eBay with chain shipped for 230$. Mill was extended with t-slot aluminum. It would be nice to be make a shorter one for my 28” bar if I ever do dimensional lumber.
When I built my MS660 clone I left the base gasket out to bump compression up a bit...it will break the starter rope all too often without the compression release being used...or just cough and rip the handle out of your hand in a way that makes you want to cuss a blue streak!And i never use the decompression,my personal saws get them plugged
Oh and i drop start most saws,another controversial proceedure
I've been slapped by the rope on my 395, not fun.When I built my MS660 clone I left the base gasket out to bump compression up a bit...it will break the starter rope all too often without the compression release being used...or just cough and rip the handle out of your hand in a way that makes you want to cuss a blue streak!
Starts pretty easily using the decomp, so no reason not to.
