Ok I got my infrared non-contact temperature gun today to measure the temp of the air coming out of the stove. How many use one? How accurate do you think they are? How much does the info effect your pellet purchasing decisions?
I measure the same spot on a blower vent fin. I don't know how accurate it is to the REAL temp, but it's repeatable so I assume that it's useful for comparisons.
I used it initially to see relative heat from different pellets and now to to adjust the air intake for maximum temp output.
Not necessarily. It depends on if you have turbulent flow or laminar flow. If you have laminar flow, there is a stagnant layer of air along the surface of the tube that insulates the tube from the air moving past it. Also the air temperature depends on how fast the air is moving along the tube. The faster it is moving, the less time it has to remove heat so it won't be as hot. Of course, since there is a larger volume of air moving past the tube's wall, the total btu's may be about the same either way. But you wanted air temperature, which really isn't as relevant as btu's supplied by the stove. IR guns will NOT measure air.Yes, good point. But I would think the hotter the air, the hotter the metal so it should give a good indication....right?
Oooops! Yes, I forgot to mention that I take 5-6 readings over 5-10 minutes and average them.its temperature will vary with the normal ups & downs of flame height. It's best to take several measurements before coming to any conclusions.
Have been using that model for years,as a mechanic.The hot wire sensor is great for measuring air out your vehicles vents,very acurate.Not necessarily. It depends on if you have turbulent flow or laminar flow. If you have laminar flow, there is a stagnant layer of air along the surface of the tube that insulates the tube from the air moving past it. Also the air temperature depends on how fast the air is moving along the tube. The faster it is moving, the less time it has to remove heat so it won't be as hot. Of course, since there is a larger volume of air moving past the tube's wall, the total btu's may be about the same either way. But you wanted air temperature, which really isn't as relevant as btu's supplied by the stove. IR guns will NOT measure air.
One other point to look for on your heat gun is whether there is a switch setting for dark or shiny surfaces, as AK13 said. I used both IR guns and direct contact probes in my work for many years and IR guns, especially cheap ones are worth a crap for accuracy BUT they will PROBABLY give you an indication of variations in temperatures as many above have said. That's all you really need to see which set up gives you more heat IF ALL OTHER VARIABLES REMAIN CONSTANT. You must change only one thing at a time for an experiment to be accurate.
If you want accuracy, then look for a used surface contact pyrometer on EBay. http://www.ebay.com/itm/Therma-Tray...615?pt=LH_DefaultDomain_0&hash=item258818346f This is a good instrument but doesn't have the right probe for surface temperature BUT that tip would slide right into your tubes and avoid touching the metal giving you an air temperature. $5 is fantastic! If you don't want it, I think I will bid on it because I don't have that probe.
http://www.ebay.com/itm/tif-7000-Th...956?pt=LH_DefaultDomain_0&hash=item2a3690a2cc This one is top of the line and very nice.
Yep, it's a great, indestructible baby!Have been using that model for years,as a mechanic.The hot wire sensor is great for measuring air out your vehicles vents,very acurate.
Just some temps I been hitting now and again, using the gun strictly for pellet choice and fine tuning stove. The pics. are a run up from stage 1 to 4 over 20 mins. Satisfaction sold at HD have my vote for sleeper pellet of the year.
It may be reading temperatures through the glass...according to those readings, you can easily ignite paper on the surface of your stove.
Great if you already have one, but a bit pricey compared to either IR or thermocouple meters available.Do none of you guys BBQ? If you do, you should have one of these already. Hang the BBQ probe in the air stream
http://www.amazon.com/Maverick-Et-732-Remote-Smoker-Thermometer/dp/B004IMA718
(even accounting for bradbury being off low by 30 degrees.)
PDF]
Ignition Temperatures
ir.library.oregonstate.edu/xmlui/bitstream/.../Bulletin%20No.%2026.pdf?...
