hello. i have been using an older model Vt.Castings Intrepid for about 6-8 years. Last owner said they didn't use it much. There have been no issues until last winter, when this problem started where I can damper the thermostat ALL the way down and the temperature still shoots up to 700 degrees even w/air inlet completely closed.
This stove used to be a dream - i could set thermostat lever and it would remain at a set temp. all day long while i was away at work. now i have no control over the temp. and it scares me a little.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Just had all the gaskets replaced, windows, doors, chimney cleaned.
Not sure what could be wrong. Do i need a new thermostat?
What is meant by a "rebuild" and is that what i need?
Thanks
Thanks
