One thing I've noticed about Harman's stats is they're very conservative. Also, are there other bottom-feed stoves in the report? I would expect a bottom-feed stove to push more ash out through the exhaust and therefore show more grams in the test.
The Englanders are bottom feeders too.btuser said:One thing I've noticed about Harman's stats is they're very conservative. Also, are there other bottom-feed stoves in the report? I would expect a bottom-feed stove to push more ash out through the exhaust and therefore show more grams in the test.
Webmaster said:Englanders are not bottom fed.......they are top fed.
I think just about all stoves other than Harman are top fed these days...might be a rare exception.
Gio said:The Englanders are bottom feeders too.btuser said:One thing I've noticed about Harman's stats is they're very conservative. Also, are there other bottom-feed stoves in the report? I would expect a bottom-feed stove to push more ash out through the exhaust and therefore show more grams in the test.
But what has top feed / bottom feed to do with how much ash is pushed out? And how does that relate to the amount of grams per hour emissions?
Gio said:Are you sure of that Craig?
I was under the impression top fed stoves drop pellets from above down a chute into the burn pot below as per lots of remarks how they often bounce out of the pot . At least the ones I`ve seen do.
Webmaster said:.....so I would not hesitate to purchase a true bottom feed....in fact, I think the advantages are many.
Webmaster said:Gio said:Are you sure of that Craig?
I guess you could call it a side feed - but, IMHO, the pellets still feed in above the grate bottom. That, IMHO, would not make it a true bottom feed. With a Harman, the pellets are not visible as they feed....probably another good definition of a bottom feed stove.
I think Earth Stove used to be bottom feed - Treager? At least as I remember. In terms of efficiency, it was the worst of the pack when tested many years ago. I suspect a top feeder has certain advantages at lower burn rates. It stands to reason that the very small hot fire gained by dropping just a few pellets on a burning bed would have better combustion in everyday use.
However, Harman has spend a lot of time perfecting their system and I certainly was impressed even 10+ years ago.....so I would not hesitate to purchase a true bottom feed....in fact, I think the advantages are many.
i think web means on an englander you can see the auger feed pellets in, on a harman you may see new pellets but you sure don't see the auger turning, unless your running it on its lowest possible setting.Gio said:Webmaster said:Gio said:Are you sure of that Craig?
Mike, I can indeed see fresh pellets feeding into the burnpot on my Harman. I just took a peek so that would rule out that requirement for defining a bottom feeder . The upper portion(1/3) of the auger tube is visible.(at least when burning on low setting)
The two (Englander and Harman) feed systems are certainly not identical but very closely related and much more similar than different. There`s an obvious difference in the height of the auger feed tubes into the burnpot.
The Englander does in fact feed pellets a bit higher into the side of the burnpot than the Harman but I still wouldn`t classify the Englander as a true top feeder since the pellets don`t fall from a chute into the pot . They are pushed in (as you say) sideways .
The Harman also pushes pellets sideways into the bottom of the pot and not actually from underneath the burnpot and I`m not even sure if there`s an upward angle on the auger but only the burnpot bottom. I guess the major difference is the height of the auger hole.
In summary , the bottom of the Harman auger hole is at the same level as the bottom of the burnpot. The bottom of the Englander auger hole is higher than the bottom of the burnpot.
I wonder how Mike Holten classifies the Englander feed system?
You're right. I have read the report that this table is based on. Nothing at all to do with stove efficiency or meaningful comparisons between top-feed or bottom -feed models.StrangeRanger said:How are you guys getting efficiency out of that table at all? To me that's simply a listing of stove exhaust output. Am I missing something? It's a listing of stoves eligible for Oregon's tax credit program.
macman said:Gio said:....I was quite surprised how well all of the Englander models fared. Considering most of their line is sold thru big box stores this brand did excellent....I`m looking to get me an Englander pellet stove for the rear shop , replace my wood stove out there ........
Not to get anyone with a Harman stove upset, but how is it possible that the mighty Harman stoves, that are the "be all and end all" for so many people, got their efficiency butts kick by the Englander stove in almost every case??????? Any ideas, Harman people??
Have you guys been following this thread? It has been stated several times already- this is a list of clean burning stoves that qualify for a tax credit based on particle emissions. How does anyone conclude output efficiency from this?NH Pellet Head said:macman said:Gio said:....I was quite surprised how well all of the Englander models fared. Considering most of their line is sold thru big box stores this brand did excellent....I`m looking to get me an Englander pellet stove for the rear shop , replace my wood stove out there ........
The only analogy that I can come up with is the different between a cyclist riding a regular bike vs. one of those guys riding a recumbent bike down the road...sure, the recumbent bike is a lot more efficient and easier on your back, but it doesn't look that cool.
Just my biased opinion![]()
BDPVT said:Have you guys been following this thread? It has been stated several times already- this is a list of clean burning stoves that qualify for a tax credit based on particle emissions. How does anyone conclude output efficiency from this?NH Pellet Head said:macman said:Gio said:....I was quite surprised how well all of the Englander models fared. Considering most of their line is sold thru big box stores this brand did excellent....I`m looking to get me an Englander pellet stove for the rear shop , replace my wood stove out there ........
Oh, that was a joke? Sorry i thought it was just a poor analogy!NH Pellet Head said:BDPVT said:Have you guys been following this thread? It has been stated several times already- this is a list of clean burning stoves that qualify for a tax credit based on particle emissions. How does anyone conclude output efficiency from this?NH Pellet Head said:macman said:Gio said:....I was quite surprised how well all of the Englander models fared. Considering most of their line is sold thru big box stores this brand did excellent....I`m looking to get me an Englander pellet stove for the rear shop , replace my wood stove out there ........
Thank you, Captain Obvious (aka BDPVT)! Jokes ARE allowed in the threads, yes?
BDPVT said:Oh, that was a joke? Sorry i thought it was just a poor analogy!NH Pellet Head said:BDPVT said:Have you guys been following this thread? It has been stated several times already- this is a list of clean burning stoves that qualify for a tax credit based on particle emissions. How does anyone conclude output efficiency from this?NH Pellet Head said:macman said:Gio" date="1258000501 said:....I was quite surprised how well all of the Englander models fared. Considering most of their line is sold thru big box stores this brand did excellent....I`m looking to get me an Englander pellet stove for the rear shop , replace my wood stove out there ........
