This is my first post, so all input is greatly appreciated.
My 3000 sf house in northern VA is currently heated by a 80% propane forced air system for the main floor and basement, while the upstairs is heated by a heat pump. We spend about $2000+ each heating season on propane, not sure of the adder for electric heat pump. I have been lurking here for awhile and like the wood gasification systems and am considering one. Retro-fitting radiant floor heating is not do-able as the underside of the floors are all finished spaces and am not interesting in tearing out ceilings or floors. With minimal drywall cutting, I can get access to the furnace and heat pump units for installing water to air coils, although this access would be through unconditioned spaces so freezing of the water lines would be a concern.
I have a large unfinished basement storage room (25x17 with 9 foot ceiling) that could become "the boiler room". This room is on an exterior wall, has walkout access, an adjacent covered area to store a large amount of wood (several cords) under a deck, a clear unobstructive side on the house where a pre-fab chimney could be located (framed in and vinyl sided), domestic water lines, and acces to power for new circuits. This room is on an end of the house, while the existing propane furnace and water heater are in the middle of the basement and the heat pump is in the unfinished attic. I also have a 1500 sf detached garage that has propane heat.
In looking at these systems, they all seem "home brewed" to a certain extent. As a mechanical engineer, the supply/return concept with storage seems rather straight forward to me (I like Nofossil's web site). Before I get too deep with the thought process though, I need to determine the rough order of magnitude (ROM) budget estimate for the various pieces of equipment (wood furnace, new chimney and flue, storage tanks, circulating pump(s), water to air heat exchangers, piping, etc. I am more than compete in electric, plumbing (copper and threaded), and sheet metal skills so the labor part of the ROM can be excluded. I had inquired about a Tarm a few years back but the $6k plus figure back then made it a non-starter. It looks like today, units like the EKO's can be had in the $3-4k range. I even see there is an "econoburn" gasifer reportedly made in the US but no idea on costs - strange that the cost information for these units from the various vendors are not posted - top secret I guess.
Any event, would appreciate your thoughts on the $ involved for a system that would suit my needs. Wood in my area is $150-175/cord so even at $175/cord, that would be almost 11 cords worth of wood compared to my propane bill. Not sure what your experience is, but I would not expect to burn anywhere near 11 chords here in NOVA. So, the pay back should be there even if I didn't cut my own wood.
Thanks,
-larry
Thanks,
-larry
