Hi
I have a wood stove that I got used that was insulated and I am looking for insulation that is non toxic that I can use in my stove. In all my research I have found none except hemp, however I have never seen it used in wood stoves for insulation for inside a wood stove. Any recommendations? Any type of insulation that is non toxic or perhaps green certified?
The most common on the market seems to be ceramic fiber and before that was asbestos, however each has toxic risks to both of them. In my wood stove there is insulation between the lid and the metal part of the stove as well as the inner sides. I approached this problem when I installed the wood stove and saw that it was smoking from the inlay (outside) of the pipe, it would appear that the insulation was burning. The chimney pipe was not sealed so we will be doing that (as before there was soot and burnt ash all around the pipe) and because of that we will be replacing with new insulation because we took insulation the burnt/smoked insulation out. We wire brushed it and sand papered around the pipe and inside the border to prepare to caulk it with speacial caulk around the pipe so it is not just a good fit , but so that nothing seeps out.
![Insulation for used wood fireplace Insulation for used wood fireplace](https://www.hearth.com/talk/data/attachments/300/300358-995c9ede94e8ad4dff44b96a0d08c12b.jpg)
![Insulation for used wood fireplace Insulation for used wood fireplace](https://www.hearth.com/talk/data/attachments/300/300356-454bc9f641132df2fcb036f7e87535e0.jpg)
![Insulation for used wood fireplace Insulation for used wood fireplace](https://www.hearth.com/talk/data/attachments/300/300357-e733860ac7e1a6ce091d7f174077a554.jpg)
