Scarecrow57 said:If I understand this right we have several objectives within the system.
1. Burn hot
2. Provide Storage - More is better?
3. Get the heat from the storage to the living area efficiently.
Questions:
What is the R value typically used on the Storage system?
Where is the storage typically placed? Close to the boiler or near the living area?
Thought
By constructing a water tight insulated cavity in the ground and then filling it with a medium I provide a means to get the heat from point A to point B as well as establish some heat storage.
The basic problem you're up against is that it takes proportionally more insulation to insulate a long skinny heat storage device than it would for a short fat heat storage device of the same volume.
Yes, with enough insulation it could be made to work, but you might well be happier spending less money to build a more compact heat storage device elsewhere, preferably somewhere where the heat loss from the storage device would escape into a space that needs the heat.
Another problem is that in the situation where the heat in the concrete pipe is depleted and perhaps the house is a little cooler than you'd like, you have to wait for the concrete pipe to heat up before you can get the house to heat up as fast as you'd like.
--ewd
