TomasB
Does that inside layer more likely to snag when you use a spinning broom on a flexible shaft, or a regular one when cleaning with up/down motion?That thin inner layer gets snagged when cleaning leading to a hot spot that makes it get worse
I can see a spinner being a bit more safe, as long as certain rotation is maintained, that doesn't try to clip on those "gills" but rather follows the direction (which I will definitely need to take a note of that!)
