We're installing a see-through (tunnel) wood cast-iron insert into an existing brick fireplace. It has a masonry chimney that goes in the middle of our living room about 23ft up to the roof (so most of the masonry is actually indoors). Chimney opening throughout the entire length is 13" and lined with ceramic and has a small elbow in the middle (so can't really run a rigid liner).
The stainless liner is supposed to be 8" according to the manufacturer. My installer tells me that we don't need to insulate the liner as it's technically indoors. Is this actually true and not any code violation?
Any recommendations here? I'm not trying to avoid extra insulation cost but just wondering what would be a better solution. We're also supposed to have an intake register below the insert and then a register (exhaust) higher up above for convective air circulation and maybe uninsulated steel liner would work better for that?
