Hi,
I hope everyone had a good holiday!
I'm trying to install a wood stove and I am running into some issues. Ideally I would like to have the chimney go straight up through the ceiling and roof. I didn't want to do this as we have radiant heat in the ceiling. So then I decided to go out of the wall. Next issue I ran into here is there is a 2 ft soffit overhang over the house. I didn't see an issue with this until I took my stud finder and found that there is a stud directly in the middle of where the chimney would go. I cant move the stove as where it currently sits is where it must be.
Does anyone have any experience going through radiant ceiling heat? What are your thoughts on this?
Can we cut the stud and block it in somehow? If the stud is in the way then the roof stud would be in the way as well which adds to this problem?
Don't be afraid to hurt my feelings, I want this done correctly don't need any house fires!
Thank You
Kris Burns
![Installing Wood Stove (First Timer) Installing Wood Stove (First Timer)](https://www.hearth.com/talk/data/attachments/270/270361-c9a8b5a0ee9369d0e71de44bdcae08d3.jpg)
![Installing Wood Stove (First Timer) Installing Wood Stove (First Timer)](https://www.hearth.com/talk/data/attachments/270/270362-4c28b8c6daaf77f2e4d74201a6da46ea.jpg)
Thank You
Kris Burns
