As a carpenter i know all about codes an inspections. IMO an outdoor wood heat source is much safer. I am interested in making a safe outdoor wood fired heat source. Just asking for ideas I am capable of constructing a safe and economic outside wood burner.bhollerI know post: 1967185 said:Well if you have only had one incident in 30 years then you don't need to follow those pesky codes or instructions you will be fine.
Sounds like sound advice to me2. Do not install this furnace in a mobile home or trailer.
Right from the hotblast manual pretty clear
…in a non permanent "old insulated job trailer". Come on man, what do you think to yourself when a homeowner says something like that to you? You DO know about codes and inspections if you're a pro. You know there is a reason for them, and you know that your rig wouldn't pass any of them. No reason to die in your sleep just to get another old house remodeled.I am capable of constructing a safe and economic outside wood burner.
Ok let's get away from the trailer idea. I think I have not conveyed my idea properly. Let's say I have a small metal building that I can move that I would like to mount a wood burning furance in for a heat source for my home.2. Do not install this furnace in a mobile home or trailer.
OK letsuote="bholler, post: 1967209, member: 32126"]2. Do not install this furnace in a mobile home or trailer.
What is standard for OBW distance from a ocupied structure.Do you have to pass inspection for this installation? Is there insurance on the house that would cover this installation?
I could make it a perment structure but would rather be able to move it in the off season.brenndatompercent : 1967225 said:So you are saying the wheels are coming off...and sitting directly on the ground or some sort of foundation?
Wow that would be a strong wind.If I decide to go with the trailer idea I was planning on making concrete block surround that would weigh approx. 2000#I've never been to Iowa but I would think y'all get at least as much wind as us in the winter...having a fire goin in a trailer that could blow over into my house would make me real nervous
Putting it in the house is not a option. I understand that the stove that I have is not the best but for what it cost me (free) I think I can make it work. Most of the heat loss will remain in the trailer I would think. Yes a boiler would be great but I believe it would take to long to pay for itself. I only really need to heat the the first floor of the house anyway. I was just wondering if anyone has tried this before.I'm sure I could make it work but if I would need an extra inline blower to get hot air into the house combined with heat loss.
You're behind an 8 ball to begin with, with the furnace you have. It is inefficient to start with, sending a lot of the heat from the wood it eats up the chimney to outdoors. I.e., poor heat exchange to the ductwork. The only thing that moving more air through it will do, is make the air coming out cooler.
At least with this furnace in the house, you would keep some of that heat loss in the house - the heat that also radiates off it. If it's outdoors, you will lose that too.
You are getting sound advice from everyone here.
