I've got everything I need to finish installation on my NC30, but I haven't done this before. I was hoping for some help clarifying some basic things that have been hard to find on a search for some reason. It seems to be a clear case of "this is so basic no one talks about it."
As you can see from the pictures, I'm installing in a hearth and then into the wall connected to the chimney. The stove is replacing another one that was previously installed.
How close can I get to the wall? The manual lists some clearances, but I'm not sure that applies since I have a real stone wall (one foot thick). On the other hand there is wood paneling next to it, so maybe I want to have a particular clearance anyway.
My other question relates to connecting into the wood stove itself. Does the crimped side go directly into the top of the stove itself, or can the uncrimped side rest on the lip?
I also have a 12" slip to go with the 24" pipe to get enough length. Does the slip go above or below the pipe? Does it matter in which direction? Are screws used with this piece?
Lastly, I'm putting in a damper. Does it matter where along the pipe it's installed?
Thanks for your help! Again, I know this is pretty elementary but haven't been able to find instructions.
