Hi!
So I’m building a cabin from scratch and it’s time to build out the area for my wood stove! It’s going in a corner that I’ve already insulated and put up vapor barrier. I’m ready to install the fireboard/cement backer, but I’ve run into a question that Google cannot answer. Do I remove the plastic vapor barrier and the paper backing on the insulation before putting up the cement boards? And does there need to be an air space between the cement backer and the studs? The insulation is fiberglass batts with the paper backing. The vapor barrier is 5mil plastic sheeting
I’ll attach a photo of the walls.
![[Hearth.com] Installing fireboard, need help! [Hearth.com] Installing fireboard, need help!](https://www.hearth.com/talk/data/attachments/296/296141-b4c1ccfa56678ba368d8f7fe9d749bd7.jpg?hash=JSiHnAP1km)
