Forgot the link, as usual I clicked too quick! (broken link removed to http://www.northweststoves.ca/chimneys-venting/selkirk-direct-temp.html)
Glowball Worming Bust said:cant use gas pipe on a pellet stove.
That was my first thought but if you click on the pellet link it takes you to the brochure where they say their VP version is approved by UL for corn & pellet burning appliances.Glowball Worming Bust said:cant use gas pipe on a pellet stove.GotzTheHotz said:Forgot the link, as usual I clicked too quick! (broken link removed to http://www.northweststoves.ca/chimneys-venting/selkirk-direct-temp.html)
mralias said:Found what I was looking for. This site has the Z flex 2" pipe kit that is made for the fresh air vent. Cost me $62 with shipping from TX for 25' kit. If anyone is looking for a fresh air kt for the CB1200i Quad and want to run it up the chimney this is the place to get it. Even the place I bought the Quad from said they could not find 2" flex for venting and Quadrafire did not sell it.
(broken link removed)
You have to call them by phone for the 2" as it is not on their website yet as it is pretty new by Z-Flex. Don't call Z-flex for this as you have to go through one of their dealers.
FredJ said:mralias said:Found what I was looking for. This site has the Z flex 2" pipe kit that is made for the fresh air vent. Cost me $62 with shipping from TX for 25' kit. If anyone is looking for a fresh air kt for the CB1200i Quad and want to run it up the chimney this is the place to get it. Even the place I bought the Quad from said they could not find 2" flex for venting and Quadrafire did not sell it.
At 20' long I would also suggest, as Giovanni did, that you up the diameter to 3" or even 4" and use a reducer at the stove. 20' especially if it has bend will have a lot more resistance to pull through that an much shorter run. I wouldn't want you to finally decide on an OAK then have it not supply enough flow. Too large wont hurt anything, too small will starve the flame.
rona said:they do make a vent that opens and closes automatically that fits in the wall but with the stove running full time which I assume it will be you will be letting cold air in your basement all the time unless you plumb a pipe into the vent that opens and closes and thereby capturing the cold air and not allowing it the run of the basement. cooling things off.
Glowball Worming Bust said:yes! more oxygen & nitrogen too= denser air. air is mostly nitrogen which dont burn [inert]slls said:BrownianHeatingTech said:ssman said:What about all furnaces and water heaters? All of these require combustion and emit exhaust and they don't require OAKs. Where is all their makeup air coming from? So I guess if you own one of these units you will need to put an OAK on it too!
You should. High-efficiency appliances require or at least offer the ability to use outdoor air.
Sealed combustion is the best way to go.
Liter of Cola said:If you cut the hole for an OAK, the cold air is drawn directly into the stove, meaning that this cold air is constantly cooling off the stove, and you have to "burn more pellets" to heat the stove.
The inefficiency in a stove is not in the combustion, itself. Combustion air that is 20 degrees colder does not mean a flame that is 20 degrees colder. You could put a larger and larger heat exchanger on a given system, and cool the exhaust more (combustion efficiency is the difference between the flame temp and the exhaust temp). However, if you did that, there would be problems of draft and corrosion and soot, because the exhaust was too cool.
The amount of energy the system will waste is fixed by that, regardless of the amount of energy that it consumes in combustion. Colder air means it needs to consume more energy to pre-heat that air, but that extra energy is captured by the system in order to cool the flue gas just enough, but not too much. The energy has to go somewhere - into your house. Colder air (as long as it is not so cold that it interferes with proper combustion) will actually increase efficiency. It sounds counter-intuitive, but the thermodynamics do work out.
If your house is tight enough that it needs additional fresh air, replace a bathroom vent with a HRV, and install a ventilation controller to turn it on as needed.
Joe
Would cold dry air have more oxygen per cubic foot than warm humid air. If so how would that effect combustion.
Glowball Worming Bust said:but why is the air preheated in older carbureted engines from heat tube from block to air filter cannister?
Glowball Worming Bust said:&WHY;DO ALL CARS GET WORSE MILEAGE IN WINTER i think.
I've never had a car that got worse mileage in the winter.
Joe
Glowball Worming Bust said:http://www.cartalk.com/content/columns/Archive/1997/March/01.html
(thats why race cars do not use air)Glowball Worming Bust said:In winter, colder air means denser air -- more molecules per cubic foot. At any specific throttle setting or opening, the same number of cubic feet of air, but containing more air molecules, will enter the engine. The computer will provide more fuel to create the proper air/fuel ratio at that moment. This is a bit more subtle, since "more air/more fuel" produces more power, so you may be able to operate at a slightly lower throttle setting -- sort of rebalancing the equation.
Glowball Worming Bust said:as to pellet stove,i'd think that the combustion air intake would be set to feed air for the highes burnrate so that full combustion is assured. burn pellets at a lower rate + add condensed cold air factor & the result is excessive airwash from heat inside stove. kindalike heating the outdoors, eh?
