E
elkimmeg
Guest
There is quite a difference between a power venter and a direct vented appliance
Ok the only way this stove can be set up efficiently a magnaholic, ( I know I miss spelled it ), draft indicator is attached threw the access panel
within that panel there is a set screw adjustment set according to the voltage in and measuring the draft. It fine tunes the stove's efficiency
Similar to what a timing light is used to correctly set you're car timing. The car may still run, skip, hesitate ,burn fuel inefficiently, have no acceleration, cough backfire, but still runs.
But till that light gage is used you are only guessing the correct final adjustment. You need that gage to fine tune and dial it in
