I have been reading here for a few months and have learned a bunch of stuff (raking coals to the front, shutting off blowers when cold start or reloading, moisture meter). Lots of great info here for sure. This might get long....
So I ran an insert (Earth Stove) in the basement for 3 years. I got smoke back in the basement after a couple of days, I found out the flue tile was blocked at the top with door screen and it plugged up. Was told I needed it lined so had that done with insulated flex stainless steel. Worked fine after that. We stopped after we had geothermal installed and I was working 3rd shift and thought it was unfair for my wife to have to do all the work at night.
Been heating with the insert on the main floor for several months now. Current wood is Ash, Oak, or Hickory....around 23% moisture content. That's all I have ready to go since I didn't know we were going to heat steady with wood again. After learning to get the firebox up to temp by shutting off both blowers (580 CFM total on high) I watched the window glass temps with the IR gun run to 590 and started to cut it back to half the air. Turned on the blowers and air was real hot as expected. Windows and door frames started to drop temp and then go back up slowly as I read they should do. Cut the air down again to less then a 1/4 and finally barely cracked open. Got really lazy flames as expected, some yellow buts lots of blue. It was hot
I knew my windows weren't sealed tight by the clean areas on the glass, also one area of a door was definitely not sealing. Shut the air down as tight as it would go and still had rising temps but leveled off around 650. It started dropping then but the load of wood didn't last thru the night. I knew I needed better control of the air.
So it's been warm here in Illinois and I replaced all the door gaskets and the window gaskets. Couldn't find the window gaskets that were wrapped around the glass so replaced it with a layer of flat on the door frame and a layer on the frame that holds the windows in place, so gasket on front and back of glass, figured better seal? Cleaned and oiled both blowers while I was at it. First overnight fire last night same routine, blowers off, loaded with 23-24% Hickory over some hot coals, both vents wide open and the door cracked to get it going. Let the heat get to 500 this time and closed the door and shut the air to half. Got it stabilized at about 400-450 on the windows before bed with the air vents about a 1/16 open, lazy flames at 10:30. Wife wakes me up at 2:30 and says it smells hot down stairs. Go down and it's running 650 on the glass and 590 on the door frames, I close the air down all the way and have 275 + degree air coming out of the air discharge. 155 temp on the hottest brick above the face plate behind the insert, dropped to 100 about 5 rows up and cooler on up. Lots of lazy blue flames only and lots of wood to burn thru yet, started with 6 pcs(full). Monitored the temps for 20 minutes and it wasn't going down so I placed the 12" fan we use to push air deeper into the house facing the insert to pull heat away. That was working as I hoped, temps slowly down to 475 -495 on the glass and door frames. The center collapsed on the pile and didn't change the flames at all but after watching it with the fan blowing on it, temps finally started to go down when I took the fan off it. I'm guessing those temps were my peak of the cycle? 7:30 it was full of coals and I started it back up for the day. Windows both black with one small area hazy you could see flames thru.
So here's the info on the chimney. It's 13" square tiles and full brick all exposed and it's tall...24' off the top of my head and just under 7.5' wide. Just had the top 5 courses replaced and the top flue tiles too. This one is not lined at all and the draft is crazy good. Main floor flue is the middle one and the basement lined one is to the left.
The insert is from 1981 ish or so. The air comes in the lower front two knobs on the front and is pulled thru to the center of two heavy 3 sided runners going front to back. No longer in business so dead end on any operating temps for it. I actually have another one of these in a detached finished garage that the previous owner built as his man cave. We've lived here 18 years.
Was I on the verge of an over fire? event last night? All the air was shut off so I was not expecting to not control it after new gaskets. Too good of draft??? It was 15-20 mph winds and about 28 last night. Wasn't looking forward to lining it....not sure how that would have changed the situation last night. Would like to get more air flow from the fans but not sure that possible....might help me pull more heat from it? What do you all suggest? Makes my wife nervous when things get that hot. I'll try and ad pictures of the fire last night thru dirty windows, insert and info on it, and the chimney.
Thanks,
Steve
![Insert Running Hot Last Night Insert Running Hot Last Night](https://www.hearth.com/talk/data/attachments/236/236375-5aa5735958e60ac39eeb3b09214c7ca0.jpg)
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks,
Steve
![Insert Running Hot Last Night Insert Running Hot Last Night](https://www.hearth.com/talk/data/attachments/236/236372-180ff9672f50222d622c48ef8aa7c75e.jpg)
![Insert Running Hot Last Night Insert Running Hot Last Night](https://www.hearth.com/talk/data/attachments/236/236373-039e979ef26ab5148d08d3a3c755ad95.jpg)
![Insert Running Hot Last Night Insert Running Hot Last Night](https://www.hearth.com/talk/data/attachments/236/236374-2bedd3c61bbf3eb58b96a1829f513ad0.jpg)
