Hi Guys,
So, glad I did my research before trying to connect a log lighter to a fireplace insert after reading all the 'KABOOM!' threads. With as forgetful and easily distracted as I am, we probably would have blown the insert to the moon, lol!
We've been using the insert for a little more than a year now, and have been very pleased with the results. It sure did help with our propane costs for our house (not cheap keeping a 4k sqft home warm w/ LP)! Had a few questions about lighting, smoke, and improving efficiency.
Wood Burning Fireplace Insert Easy Start, Log Lighter Methods
What I really need is something that I can use on a repetitive basis with the door shut so no smoke gets back into the room. What products are available on the market to help easily start the fire in the fire box? I've considered modifying an electric bbq starter and somehow plugging that into the unit but have no idea how well that would work, plus you're probably talking 15 minutes to get the thing to ignite.
Smoke Control
We've been using a propane torch for about the first 3 minutes or so, but we have to leave the front door to the unit cracked so smoke get's back into the room - especially if the flue is cold and/or it's windy outside! I've tried mitigating the issues of negative house pressurization or the cold flue by starting the fires as fast as possible, cracking a window, heating the flue with a small space heater and met with varying results.
Ash Control / Cleaning
We burn a lot of wood, and have a fire going probably 60-70% of the time throughout the winter. I'd say after 3-4 fires, we have to clean out the insert of all the ash. I've tried the ash vacuums, and unless you wait at least a day (and usually 2), there are always hot coals left over. You shovel the ash out into a bucket, the ash floats all over the room. You use a vacuum and don't wait until the coals are smolder...the vacuum eventually melts or the filter gets holes - so now you have a giant plum of ash blasted into the room every time you start the thing. Just stirring up the ash with the shovel throws a bunch of stuff in the air you don't want to breathe.
The only thing I've thought of is putting a vacuum outside and running a 20' hose through a window to clean out the insert...still, that doesn't solve the hot coals issues.
Thanks for any advice/tips in advance!
Smoke Control
