Have you been running this stove with the air control/damper all the way open all the time?? *I'm asking again*
Read your owners manual for what the air controls are, it should be in there.
If you are not controlling the air with a decent fire, you are losing mega heat up the chimney. I betcha that's where it's going.
Going to hardware store to get stuff to make damper block off plate ... Just found out that my liner is 5.5 inches.. Manual calls for a 6 installer said that that's not an issue and he does 5.5's all the time after work I'm going to run the stove with the surround panel off. Would the 5.5 make me be losing that much heat? My installer says no
Isn't the heat Lways going to escape anyway since the liner is open .. Meaning that like a regular fireplace you can open and close the damper shutting off the chimney.. The chimney liner is a straight shot up the chimney never being closed off I'm assuming that's how it's supposed to be but wouldn't that make you lose heat?
That's what I think as well.. So you think the damper blocking plate with the roxul insulation will make a difference anywhere else I should place the insulationBlock off plate and Roxul not standard fiber glass insulation (roxul is way more fire resistant). I bet a good quantity of you hot air is going up your flue to heat your chimney, it needs to be kept around the stove. As I understand inserts need very good insulation around them to work properly and give good heat output.
I think that this is a good start, I have read of people stuffing the top of the chimney as well but I cannot comment on that. Can you post a picture of the stove with this thermometer on the door? I would pick up a magnetic therm from lowes or hd for a second opinion also.That's what I think as well.. So you think the damper blocking plate with the roxul insulation will make a difference anywhere else I should place the insulation
I agree with this also.Well it sure wont hurt anything.....
Also these stoves almost work backwards from what you would think. The more you turn them down the hotter they actually get. When you close the main air the draft causes more secondary air to come in the burn tubes. That secondary burn is what really gets the unit heated up.
I am at work right now I had posted a picture last night with the stove going and the thermometer placed on the top of the door..I think that this is a good start, I have read of people stuffing the top of the chimney as well but I cannot comment on that. Can you post a picture of the stove with this thermometer on the door? I would pick up a magnetic therm from lowes or hd for a second opinion also.
I would be happy with 70 in stove room and 68 everywhere else.. I can't seem to get my stove room to a 70 degree temperature .. Stays at around 62On the burn times thing:
I had a fire going all night Wednesday night, My wife was home yesterday so kept the fire going all day. Our home is 1776 ft/sq and we had temperatures ranging from 77 in the stove room to 68 in the furthest bedroom while outdoor temps were 40s during the day. About 9 pm last night I decided not to load up overnight as we were not expected to get much colder outside and the house was plenty warm, especially for sleeping. I did rake the coals forward and get them closer together for a more complete and final burn in front of the air inlet. This morning although the fire was out, stove room 72 degrees, main floor 70 degrees and leaving for work. This is because everything in the house had time to warm up and takes time to cool. No sense burning more wood if its comfortable. I will have a cooler house this evening when it's time for a new fire.
If your stove cannot even heat the room its in, it will never heat your entire house. Either your wood is not dry,or your stove is malfunctioning. No matter how small the stove ,it is certainly rated for more Sf than the room its in.I would be happy with 70 in stove room and 68 everywhere else.. I can't seem to get my stove room to a 70 degree temperature .. Stays at around 62
Exactly... How would you tell if the stove would be malfunctioning.. Wouldn't I be getting smoke In the room ?If you stove cannot even heat the room its in, it will never heat your entire house. Either your wood is not dry,or your stove is malfunctioning. No matter how small the stove ,it is certainly rated for more Sf than the room its in.
I have not determined is wood is dry enough yet... It's mostly oak at least 9 or 10 months oldThe roxul and block off plate should make a difference, I think my room was 3 degrees hotter after I installed mine so you definitely lose some going up through the opening.
Have we determined that your wood is dry enough? How long seasoned, what species, sorry if answered already I'm losing track of these threads.
OK, we just discovered 90% of your problem, can you get some drier wood somewhere else? How about some envi blocks to mix in. I've tested oak after 2 full years of drying and still be in the mid 20's, I usually wont burn oak for 3 years.I have not determined is wood is dry enough yet... It's mostly oak at least 9 or 10 months old
I'm trying to find someOK, we just discovered 90% of your problem, can you get some drier wood somewhere else? How about some envi blocks to mix in. I've tested oak after 2 full years of drying and still be in the mid 20's, I usually wont burn oak for 3 years.
Buy some kiln dried firewood bags from a local gas station or grocery store and see if that makes a difference. 9-10 month old oak C\S\S is still 14-24 months away from being ready.I'm trying to find some
All I really have is oak I believeBuy some kiln dried firewood bags from a local gas station or grocery store and see if that makes a difference. 9-10 month old oak C\S\S is still 14-24 months away from being ready.
