Insert Broken Fan Knob Control?
Dix
6,704
Long Island, NY
Go to tend the insert this evening, and see this (actually, the knob was upside down).
[Hearth.com] Insert Broken Fan Knob Control?
Further inspection reveals this - [Hearth.com] Insert Broken Fan Knob Control?[Hearth.com] Insert Broken Fan Knob Control?
PE Pacific D1 (Super) , installed 9/08.
Can I glue while I wait for a replacement?
Anyone else had this problem?
All else working fine.
Luckily for me, the fan is set to the coldest weather position, which is coming Saturday.
You can try and superglue it back, but be careful or the shaft could get glued to the collar. Release the broken end from the knob by loosening the setscrew. Apply the glue with a toothpick to control spread. Apply a light, thin coat to both pieces. It will need to held in place steadily for a minute or two so get comfortable. Then let it set for an hour. Don't put the knob back on the mended shaft. Instead, use fingers to turn the speed until the new one arrives. There will be less leverage on the mended shaft that way.
Reactions: Dix
I went to the PE website, the Pacific manual does not include the knob assy. The Super manual does. How to tell if they are the same????
Did you glue it? If not yet, you may be able to coax it around to high speed by using a small flat head screwdriver.
No, I did not.
This house layout works best with the PE fan on low in colder temps, and 2 (one second story, one in stove room,) ceiling fans pushing down when the temps get really cold (air feel Sunday is 1F :mad: <note BB fav emoji here :) > should be fun !!)
Aye! Nudge that rheostat up with a flat blade. Time for some real heat.
