Recently acquired my first wood stove (catalytic insert really) & I've learned quite a bit already from the googles & forums here but could use some advice / anyone's comments on this insert, having it installed, & using it to heat my ~1700 sq ft. 2-story home. I'm excited to get it set up and have that first burn but want to make sure I get the best parts for the money & have it done right!
I've used my parent's insert & woodstove before, both of the older style with blower fans, but haven't seriously looked at it all until now.
It's a Carolina Challenge II insert/stove freshly refurbished from someone who does this often & it looks to be in good shape:
- welds in the firebox and all around look solid
- nothing seems warped
- 3 speed fan runs nice & quiet on all positions (unsure if the auto setting works)
- new firebrick
- new door gaskets
- ceramic catalytic combustor looks to be in good shape
I understand the company used to be Bat Cave and is now (broken link removed to http://www.highvalleystoves.com/about.php). I'm curious if it's somehow a Challenge III model as the specifications plate has the "Challenge II" part scratched out and a very clear "III" scratched into it. (picture attached)
((broken link removed to http://www.ebay.com/itm/CAROLINA-Wood-Coal-Burning-FIREPLACE-INSERT-Stove-Burner-Woodburning-/111847747649?hash=item1a0aa53041%3Ag%3AH2sAAOSwNphWbUXD&nma=true&si=C9MAYnkGCCBQ9fH3%252FlAPbK0Cvhg%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557)has more info, I can take the link down if it's not kosher)
8" Chimney Liner
I've had 3 quotes to install an 8" insulated stainless steel liner and have been researching brands/alloys/types to figure out what I want to go with. Currently looking towards single-wall heavy flex 316Ti liner, though honestly I get the feeling even the budget 0.005" 316Ti liners would be fine with 1/2" insulation wrap if I'm careful to sweep with non-metallic brushes. It seems they all have "lifetime warranty", but that probably doesn't include paying anyone to have it removed & reinstalled, so I'd like a nice durable liner that'll hopefully last a decade+ with moderate use (likely won't heat the whole house with wood full time every winter).
The heavy flex (0.010"-ish) 316L liners look to be the current winners on price vs. quality for wood & maybe a bit of coal burning but I'd like everyone's suggestions on what liner to go with.
After finding some comments here on them I've ruled out the "smooth wall" two-ply type liners for fear of delamination during installation, but I haven't seen any pros/cons to the double wall pre-insulated liners (though I'm not sure that type would fit in my chimney with the extra thickness/inflexibility).
(* Side note: the local companies I found need to actually include what brand/type of liners they're installing on their quotes, none of them did and when I called later one said: "No one's ever actually asked us for details on the liner". Wow. They would've used a 0.005" 304 alloy liner if I hadn't mentioned this insert is also rated for coal.)
Installation Notes
- Current gas line, logs, & glass doors will be removed. They're not the good kind that radiate heat anyway.
- 25' mostly exterior (bottom half is in attached garage) brick chimney w/ clay flue tiles will first be swept & inspected
- Double lintel doesn't leave much vertical space
- Decision between pushing insert back further into fireplace & re-mounting surround further forward than OEM or using some sort of sliding adapter hat to join the insert's exhaust to the flex liner (leaning towards pushing insert back, better draught with a direct mounting)
- Current rectangular flue damper & some bricks will be cut out to allow the 8" flex liner to fit
- Liner would be wrapped in 1/2" insulation & then a stainless steel mesh
- There's a decent offset to the flue that the liner might not be able to bend past, so an adapter would be used
- I think the quotes currently would just use mineral/rockwool insulation stuffed around the liner in the first section of flue to seal it in. Would it be better to have a metal plate fully sealed to the brick & liner there?
More Questions/Thoughts!
- Do the surround plates need to be installed, or would it radiate heat better without them (since it's meant to be installed both as an insert or freestanding stove)? Would it still be to code? What if heat shields were attached to the edges of the brick to ensure the wooden mantle surround doesn't heat up?
- It'd be really nice if not using the surround plates would give me enough space fit a cooking pot/pan on that top edge. I also like the look of it sitting back among all the brick better than the flush look with the metal surround plates blocking the opening.
- Should a key damper be installed in the flue? It has a single air inlet adjustment on each side of the door and a pushrod to engage the catalyst but no other adjustments.
- Suggestions on catalytic combustor thermometers / mounting ideas
- Is the Condor Watchman electronic thermometer any good? I'd need one with a longer probe than the typical ones come with (maybe 2' or so?) to reach the combustor which is directly below the flue opening.
Mad Scientist Mods:
- There's nothing to block flame from directly hitting the catalytic combustor, could a DIY flame impingement plate be welded in?
- Should I add another strip of gasket vertically along the edge of the right door? That section where the doors come together would just be metal on metal currently (not airtight?).
- Should I add gasket to the ashpan? The ash cleanout door is fairly tight but air could be pulled up from there past the unsealed ashpan.
- Should I add a course of firebricks along the inner wall of the firebox? There's just a layer on the bottom currently. No tabs or other securing mechanism for bricks to be ran along the sides.
- Any other ideas on modifications for safety/efficiency?
</end wall 'o text>
Finally pictures! Everyone likes pictures ( ͡° ͜ʖ ͡°)
- new firebrick
- new door gaskets
8" Chimney Liner
Installation Notes
Mad Scientist Mods:
</end wall 'o text>
