SpaceBus
You don't need propane tanks, there are other solutions. Here is a site assembled option: http://www.americansolartechnics.com/products/heat-bank-storage-tanks/
Ah those look slick. Suppose if I could have them build a taller skinny one it wouldn’t be so bad.You don't need propane tanks, there are other solutions. Here is a site assembled option: http://www.americansolartechnics.com/products/heat-bank-storage-tanks/
I've seen another member here use an old tank that looked like a refrigerator, maybe it was a milk tank or something. How large is your home? The larger the storage the longer you can go between batch burning. If your house is not huge and you don't mind burning a few batches per day 550 gallons would be fine. You certainly won't get creosote accumulating in the stove with storage, and you can get used to burning what you have and upgrade later. I'm sure the minisplits weren't cheap, but they will also be able to carry the majority of your heating load during the year. Then the boiler with storage would be more than capable of handing the house during the cold parts of winter. I'm sure once you experience the radiant heat from the boiler and storage you won't even want to use the minisAh those look slick. Suppose if I could have them build a taller skinny one it wouldn’t be so bad.
It’s 1344sq ft main. No heat in basement yet maybe someday. It’s a Wausau home built in 72. Has newer windows and it’s well insulated. My heat loss is around 36k btu on a -1 degree day. I’ve got 81’ of baseboard so I’m at around 45k btu output at 180 degree water. My Weil McLain is 88k output and the wood boiler is 150k. I found the old manual for it. The minisplit is great for mornings to just take the chill off when it’s going to be warm during the day or I get lazy or propane skyrockets. I got it at cost so I’m not to much money into it. Our last house I put an insert in the basement and heated it mostly with that so I’m not completely new to burning wood. I moved all my wood from the other house and just brought home 2 trailer loads of ash. I’m ready to burn lol.I've seen another member here use an old tank that looked like a refrigerator, maybe it was a milk tank or something. How large is your home? The larger the storage the longer you can go between batch burning. If your house is not huge and you don't mind burning a few batches per day 550 gallons would be fine. You certainly won't get creosote accumulating in the stove with storage, and you can get used to burning what you have and upgrade later. I'm sure the minisplits weren't cheap, but they will also be able to carry the majority of your heating load during the year. Then the boiler with storage would be more than capable of handing the house during the cold parts of winter. I'm sure once you experience the radiant heat from the boiler and storage you won't even want to use the minis![]()
You won't regret going with the outdoor boiler. Go with either Polar Furnace or Heatmaster and skip the storage. If you have baseboard radiators you will not really be able to utilize storage all that well due to needing really hot water temps.A propane tank is out of the question as it wouldn’t fit. The only way would be if I build one or buy smaller storage tanks somewhere. I also don’t know how much storage I would need. I know my heat loss and everything I just need to figure it. I’d have to feed the wood through a window somewhat close to the boiler otherwise haul it downstairs and across the living room to the boiler room. I’ve got a shop I’d also like to heat is another factor for ditching the indoor.
Other than the old boiler what does he need to tear out? Won't he be reusing all of the existing plumbing? Just hook the incoming lines up to where the current boiler is connected. Seems to me that the OWB would require much less changes than a new indoor boiler with storage.Before you cut up all the indoor boiler stuff, are you sure you want an outdoor system? That boiler got all covered in creosote because it wasn't being burned appropriately. An indoor boiler really needs storage to not accumulate tons of creosote and smoke up your outdoor space. Outdoor boilers don't always need storage, but you will have to add a lot of plumbing. With your house being already set up for the indoor boiler, I would be figuring out a way to get storage in there and just burn the old boiler.
The manual estimated that so that’s where I got it from.I'm pretty sure your wood boiler wasn't delivering anywhere close to 150k.
I can heat the house at 0 degrees with 150 degree water right now and at 30 degrees I’m at 130 degree water. I could easily add more baseboard to get it even lower. I’ve got a 36x52 shop I had concrete poured in. It will be insulated someday. That’s why I’m more leaning towards outdoor.You won't regret going with the outdoor boiler. Go with either Polar Furnace or Heatmaster and skip the storage. If you have baseboard radiators you will not really be able to utilize storage all that well due to needing really hot water temps.
Wood handling can make or break an indoor setup. I've got a wood chute system as well as a holding bin and additional stacking space. I would never want to carry all my wood through a doorway, down steps, or any other unhandy way.
Heating more than one building is where outdoor units shine. Assuming proper insulated lines are used.
What are your plans for that shop? Could you wall off an area big enough for a boiler and wood? Some OWBs can be installed indoors also. I think. Then you'd capture stand by heat loss in a usable space.
It'll be mostly for wrenching and holding my projects. Don’t want to give up too much real estate. I’ve got an old foundation that sets back a little and nearly halfway between house and shop I thought about putting a boiler on that. I wouldn’t mind building a shelter for it but lumber and steel is so damn expensive still. The other issue is getting the old one out in one piece. It weighs 790lbs. I suppose if I get some storage in the basement I can clean the old one out good and run it until I get my shop ready. Then make a decision.What are your plans for that shop? Could you wall off an area big enough for a boiler and wood? Some OWBs can be installed indoors also. I think. Then you'd capture stand by heat loss in a usable space.
Solid plan. The storage can also be used with an OWB, if you decide to go that route.It'll be mostly for wrenching and holding my projects. Don’t want to give up too much real estate. I’ve got an old foundation that sets back a little and nearly halfway between house and shop I thought about putting a boiler on that. I wouldn’t mind building a shelter for it but lumber and steel is so damn expensive still. The other issue is getting the old one out in one piece. It weighs 790lbs. I suppose if I get some storage in the basement I can clean the old one out good and run it until I get my shop ready. Then make a decision.
Put the boiler in the shop with storage.The manual estimated that so that’s where I got it from.
I wouldn’t be apposed to building a building strictly for a boiler and storage someday. Or at least the storage tanks or whatever I use. That’d clear up some real estate in the basement. Lot of ways a guy can go with this stuff it’s hard to make a decision. I think if I can get this boiler cleaned up and some storage I’ll run it for awhile until I can make up my mind.Put the boiler in the shop with storage.
I have a dedicated building for my boiler and storage.My backup oil boiler is in there as well.
So i have no fire in my home or chance of any carbon monoxide poising.No mess,ash or smoke in my home.My heating system in it's own building is my fire insurance.There is no fire department here,just volunteers.
Plus i have a heated workspace 24/7.
It's a 125 ft walk one way.Even at -40 i wouldn't have it any other way.
I have an Econoburn outside boiler that ended up inside.1000 gals storage.
The Econoburn is built like a tank,11 years use now,i don't see why it wouldn't last for another 25 years
I’m gonna email them once I figure out what I want for sizing. I’d like it to be as tall as possible with just enough room to get the lid off and hx coil out if I ever need it. I’ve been looking at how I can get more btus out of the baseboard i got. Weather it’s put in high output or double it up in sections. I figured out most of the formulas so now I can play with the numbers. Nothing but good advice and lots of knowledge on here thanks.I installed one of the American Solar Technics tanks. Its assembled in place and is rectangular so it takes up less space than an equivalent round tank or cylindrical tank. It is not pressurized. There is a couple of feet of space on the top of it needed to assemble it and install the coils. They are very careful to warn that the top cover is not be used for storage. I installed some "hoops" made out of 2x4s hanging down from the floor joists above. I slid some boards in from the side and can store stuff over the tank while not putting any load on it. Yes it still takes up room but a lot less than the traditional round pressurized tank. All the parts can be carried by one person through a standard door down a set of standard stairs and assembled in place.
Ideally I would swap over my radiators with radiant emitters so I drop my supply temps. As currently operated I bring it up to 185 F and run down to 140F. In real cold weather (-30F) I need to burn twice a day but anything over -10 at night I can run 24 hours. If I went with lower supply temp emitters I could run longer but would need to burn longer to charge it back up. My boiler is nameplate of 100,000 btu/hr so it takes me about 3 hours of burning to bring the tank up from 140 to 185.
Hope the underground pipe was replaced with new good stuff? It likely wasn't around when your old boiler was installed.Well here’s my final update to this thread pretty much. After hours of thinking and figuring I decided to go away with the indoor boiler and go outdoor. Decided on crown pristine series. Dealer was great and knew his stuff. It showed up today. Finished plumbing and wiring it. Filled it up and now I’m ready for winter. Felt kind of guilty cutting up the old boiler but I had no other option. After 15 cutoff wheels, several sawzaw blades, and bottles for my torch, she’s gone. Hope everyone has a good warm winter. View attachment 282350View attachment 282351
We don’t go on vacation much especially in the winter. If we actually do I’m sure I could find someone to keep an eye on it. I do have access to glycol so I could always go that route. Our last house had a drolet insert in the basement and we always ran it with dry wood and burned it good and hot once a day. Each year when I swept it I got hardly anything out of it. Seems like chimney fires are just due to operator error and lack of maintenance.Congrats on the new system. Outdoor boilers seem to have come a ways since I've been reading up on them.
Not to be a wet blanket as a fellow boiler/baseboard guy, but I was thinking recently "what would happen if there was a power outage when I was on vacation during the winter?" The answers I ultimately came up with were, get a neighbor or friend to run a generator (enough so the pipes don't freeze), or don't go on vacation in the winter. Since I don't know my neighbors well enough and have no friends, I guess I'm not going anywhere during the winter. So, referring back to your original post, there probably are advantages of a furnace over a boiler, lol.
On another note, my nearest neighbor, now passed away, had his house burn down from a chimney fire. He had an indoor wood furnace. So, I guess there are advantages to an outdoor boiler as well!
There wasn’t anything buried before fortunately. I got logstor pipe from my dealer and had it buried. Everything’s brand new.Hope the underground pipe was replaced with new good stuff? It likely wasn't around when your old boiler was installed.
