ch17011 said:
Hello all I have tried to search the forums and find the right answer. I am considering installing a Central Boiler 6048 but when I consider the cost of that unit for $8000 plus $3,000 in hookup materials (insulated pipe, heat exchangers, etc). Or I could invest in a $4,000 indoor unit and build a $1000 storage shed around it plus the $3,000 for the hookup materials. What I am getting at is if I build a shed with an indoor boiler I could save $3,000 on paper and be 3 years ahead on my return on investment.
Anyone install an indoor boiler in a shed or garage that backfeeds the house? Any suggestions good or bad?
My first adventure was with a homebuilt OWB that lasted for 4 years and then rotted out. I then purchased a CB 6048 that I ran for 2 or 3 winters. I live in a village but have almost 5 acres of property so I wasn't that concerned about covering the area with smoke as during the shoulder season I hooked the OWB up to a timer and only burnt it at night and lived off the hot water in the boiler during the day. In the middle of the winter, I would fill it before daylight, and then again after sundown to try and hide the smoke. When my father purchased a EKO, I was hooked on the decreased wood use, plus the fact that it didn't smoke up the neighborhood. I have a EKO 60 in a pole barn and I'm using the same water lines that I had with the OWB. The Central Boiler was nice as I didn't have to split the wood, I would just cut and stack it in the fall and then I would just throw it in and forget about the boiler. With the gassifier, I need to split the wood, and stack it up to dry it a year ahead to season I will burn it. At first I was concerned about how much work it would add to my fire-burning with all the extra work, but after having the gasifier for 3 seasons I realize that it is actually less work than before. Even with the splitting of the wood, I burn so much less that I'm ahead in the game.
In my opinion from using both the OWB, and a gasifier, there is no reason to put in the OWB. Even if it was more money, the gasifier in the long run will be a much better deal even if your wood is free. Free wood still takes time to process, and purchased wood costs more money.
