Certainly I would add a properly sized pressure relief valve to any pressurized device. A relief valve for boilers will have both a psi and BTU rating on it. Typical residential boilers come a 30 psi relief but you can buy lower psi also.
I put a 10 psi on any of the hydrohearth fireplace heat exchangers I came across
, when those were popular years ago..
And of course a pressure relief valve should be tested yearly as they can stick shut after time.
Treat anything with pressure with respect boilers, air compressors, refrigeration circuits, etc.
I cringe when I see compressed air lines run with PVC pipe.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
