Im ready for some pointers buck 2800
WASPKFD
92
Iowa
I have no problems other than the fan motor quit and was easily replaced,,, couple questions,,, How do I get the hottest burn,, Ive read all kinds of ideas.. but is it better with damper closed and air vents wide open???
also creosote question..
There is a time when we shut down the stove and drops below the 300 mark into creosote mode as it cools. are you making creosote during this time?
ive been able to keep it cruzing between 300 and 400 but have read best to get up to 500-600 and throttle back
and the elbows Ive installed do they pose anykind of problem? Im ready for some pointers buck 2800
Unfortunately there are too many variables to answer your questions easily. Chimney draft and fuel quality are the two most important parts of the equation. I have a 28000 and use super seasoned high quality wood. I originally ran it hotter although had a few motor problems. After speaking to the dealer I run it a little cooler now (knowing what a pita it is to change the motor). I don't let it go above 400 anymore. You also need to oil the motor at least once per year. A dealer that knows these stoves well is http://www.servicesales.com/buck-st...22_348.html?osCsid=ohnl9msdlleq3bps9vn8t2rmv3
Hey thank for the reply!!! where do ya oil the motor? mostly I burn old pipe dunnage suppose to be maple or ash 4 x 4 x 8 and cut it 3 ft long also a bunch of 18 x 18 x 6 long chopped in to 2 footers.. also have a pile of old oak....
can wood be too old to burn... the company has some old oaks been down for 5 years about 5 feet wide can I hack on it and use? also the elbows?? Ive had no problem yet????
Assuming you have a stock motor there is an oil port at one end of the motor. The dealer suggested 3 drops of transmission fluid at the beginning of the heating season. IMO, any wood is fine as long as the moisture content is below 25%. 20% is even better.
