etiger2007
That stove is hot and is doing what it should as far as the fire box, definately looks like a blower problem. Like others said contact whoever installed it to get it right, I love that insert.
Nothing wrong with that burn. Did you just clean the glass? The room the stove is in (should) be nice and warm...... (Should be).
Inserts are notoriously poor an outputting the heat they generate without the use of an air blower. If you are losing heat up the chimney because of a lack of block off plate it will make it that much worse.
Key issues I see are blower and block off plate (or Roxul stuffing).
I put fan near bottom and there is more air pushing from the top for sure.That is a vigorous fire. It looks like it could even have less air.
Talk with your dealer about installing a damper sealing block off plate if this is an exterior wall chimney.
https://www.hearth.com/talk/wiki/why-damper-seal-is-needed/
And have them pull the blower. It sounds like the blade is free spinning. In the meantime supplement the blower with a table fan pointed at the grille below the firebox.
It will, and does this mean there is definately a problem with fan or blower?Hope that helps until this cold snap breaks and the dealer can show up.
This site rocks. The man puts up a post about a stove issue and within a few hours, people have helped zero in on the problem. The handle of the original poster is FDNY: if that is your occupation, thank you for your service.
Yeah, I went to see the dealer today and he had a few units going, and I felt what type of air should be pushing out. It is the strength of an air conditioner, which I am not getting. Hes gonna look at it monday.I am having the same problem as you FDNY. Last night was -2 outside, my pellet stove broke down and for first time had to rely solely on my Merrimack. The house did not get past 50, we froze last night No way should this be happening with this stove!! I called installer and he said change the wood, to more seasoned wood. I asked about the airflow coming out and he said was normal......After reading this thread, it sounds like this is NOT normal and I should feel air blowing!
