hemlock said:
I might take some heat for this (no pun intended), but I would at least rough in for ductwork for possible future considerations. Once you have a hydronic system - that's it. You've condemed yourself to a boiler for good. Hydronic, slab heat is good to a point, so long as you have cheap fuel. What some don't consider with a slab is that you lose an element of control. It becomes somewhat inefficient to turn the heat up or down according to weather. I have in floor/radiant, and should I ever build a house from the ground up, I would personally avoid hydronic, or at the very least, rough in ductwork - and at least have the option down the road of going with a simpler, cheaper furnace, be it pellet, wood, oil, gas, etc....
As someone with a forced air system, I respectfully disagree. I have the system that I have for a variety of reasons (mostly that the house started with an air-based system and it has so far been easier to work with it than to make a total change-over).
I am also not one who inherently detests forced air (some people hate it for noise, air movement, dust movement, and electrical consumption for the blower (air is not a great heat exchange medium, so you need to blow a lot more of it around, a lot more often, compared to the inherent effectiveness of water for heat exchange). A lot depends on whether the air system is done well (ducts properly sized and located, etc). The difference between a shoddy forced air system and one that has been properly designed and installed is immense.
Having said all that, if I were working from a clean slate or doing even a major rennovation with what I know now from working on and living with a forced air system, I would NEVER go with forced air unless it were a big priority to also be able to have central air conditioning. Even a well-designed and well operated forced air system does create substantially more noise, air movement, dust movement, and electrical consumption than a well-implemented hydronic system. A well-designed and well-installed duct system involves a substantial amount of material cost and plenty of labor cost (or lots of your own time fitting tin). It's somewhere between prohibitively complex/ expensive and downright impossible to effectively "zone" air very much, so you have to heat an entire space, or nothing at all, which means that you're probably throwing significant unneeded heat into spaces that you might otherwise run cooler for at least significant portions of the time.
Air's one big point- the ability to ramp up temperature relatively quickly- can be matched or bettered by panel radiators or re-used cast iron radiators. Forced air also creates a much greater potential for pressure imbalance between different parts of a structure, which will amplify any air leakage with the outside.
I know my air system pretty well, having had a hand in installing and extending and maintaining it. It does the job, and does it reasonably well. I don't detest it, but with having gotten to know it very well, and also having been introduced to some of the other technology that is out there, I'd NEVER pick forced air from a full array of heating possibilities.
