Why the baking sodaburntime said:I burn dry wood, clean the chimney halfway and at the end of the season. If I ever have a chimney fire I would throw a damp log in or baking soda and get the heck outa there!
Carl said:I would say to shut down as much air intake as you can.
We have had several chimney fires over the years with no ill effects other than the roar of them going up the chimney. They make a chimney fire stick which emmits a chemical that removes the oxygen from the fire and helps put it out. Of course you have to ignite it and throw it into the stove, then close the door again. I have one but never used it. These fires happen quickly and you may not be near the stove to catch it in time. They don't last long either so you may have one and never know it. Another good reason to inspect your chimney yearly or have someone else do it. In my opinion I think most properly installed chimneys can stand a chimney fire with little damage. The biggest concern is cracking of flue liners in cement block chimneys, roof fires, or inside wall or attic fires from not following the proper clearances.
No fun to experience and scary. With the several we have had we didn't have to call the fire department or do anything other than wait a few minutes for them to burn out. Now if your chimney was completely full of creasote you may have more of a problem but if they burn out with a little creasote present they probably won't be to catostraphic.
Just relating our expereiences with chimney fires and may not reflect the opinion of the local fire department or city officials. :red:
colebrookman said:Carl said:I would say to shut down as much air intake as you can.
You're right Carl the local fire dept. would not agree. It's much better to call and be sure there is no extension in the walls using the thermal imaging cameras then to give the fire a chance to smolder and break out in another portion of the house while your sleeping or away. I've read about common dryer vent fires that destroyed the house and injured the owner who tried to put it out. Common sense is not to common these days. Besides it's your tax money at work. Often with chimney fires, at least at the start, there is little noise and your next door neighbor or someone driving by may see it before you even are aware. Be safe and pay your fire insurance.
HeatsTwice said:I have had 2 chimney fires in terracotta/cement/brick chimneys without harm to them.
BeGreen said:HeatsTwice said:I have had 2 chimney fires in terracotta/cement/brick chimneys without harm to them.
Now I understand the HeatsTwice better
The problem is that most folks have no idea about if or where the contractor that built the house and the mason that built the chimney might have fudged a bit on clearances. Then when one really needs the chimney to be in great shape and has a hot fire burning 24/7 - boom, pyrolysis hits. It's a crapshoot, but each chimney fire has the potential to compromise the system a bit more. They are really best to be avoided in the first place.
HeatsTwice said:Cracks in the mortar allowed plasma to reach the wood subfloor and ignite a smolder – which caught fire as soon as the fire department cut a whole in the family room floor using a chain saw.
ricardo loma said:keep a wet newspaper inside a breadbag by the stove. when chimney fires, place bag in stove. bag melts & wet paper releases steam . prof says so!
NOW LET'S READ THE FEEDBACK FROM LOCAL GENIUSES.
I burn wood.BrotherBart said:HeatsTwice said:Cracks in the mortar allowed plasma to reach the wood subfloor and ignite a smolder – which caught fire as soon as the fire department cut a whole in the family room floor using a chain saw.
"Plasma"? You have solar flares in your firebox? :ahhh: What oh what are you burning?
BrotherBart said:ricardo loma said:keep a wet newspaper inside a breadbag by the stove. when chimney fires, place bag in stove. bag melts & wet paper releases steam . prof says so!
I keep a large bag of Pook next to the stove. I don't wait for a chimney fire, I throw it in just for the heck of it and to listen to it scream.
HeatsTwice said:I burn wood.BrotherBart said:HeatsTwice said:Cracks in the mortar allowed plasma to reach the wood subfloor and ignite a smolder – which caught fire as soon as the fire department cut a whole in the family room floor using a chain saw.
Plasma is the word physicist used to describe heated air that glows. A detonating H-bomb in the sky creates a plasma cloud. Burning wood creates a plasma cloud above and in the combustion area. It’s a better word that just “fire” because all heated air is not fire but can be called plasma. Plus the word fire is ambiguous.
Sorry for the confusion.
Redox said:...Technically, he's right...
Redox said:...Pook is an enigma wrapped in a mystery we keep around here for comic relief. Right now, he's posing as ricardo loma...
HeatsTwice said:BeGreen said:HeatsTwice said:I have had 2 chimney fires in terracotta/cement/brick chimneys without harm to them.
It wouldn't surprise me if that is what you understand given your propensity to used innuendo to muddle clarity on many issues I have seen you comment on.
