I am looking for a practical solution to a problem having to do with long term heat storage.
It is a known fact that when clay is dried it absorbs considerable heat energy, and on wetting again it releases the same amount of heat. This is called heat of wetting.
Using this method it is conceivable that clay could store all kinds of heat energy, solar, wood, etc. and store it until such time that it is needed. Water storage needs to be insulated and still looses heat over time. Clay of the right particle consistency may be able to absorb and release heat fairly quickly when needed without the problems associated with water storage.
What I am looking for is practical ideas of using clay as a medium for both long and short term heat storage and ways that could be used to release that heat when needed to heat a home or for other uses. So put your thinking caps on and please give me some suggestions.
For instance, an idea that I have thought about would be a series of plates not unlike a car battery made up a clay in a sealed tank. Dry heat via hot water pipes could be pumped into the tank drying the clay which absorbs the heat. Then when needed the tank could have water put into it and the clay would release the heat.
