I have a direct vent gas insert installed in my fireplace. The vents are run up the existing chimney with an external wood framed chase.
My problem is that I get a build up of ice inside the aluminum soffit adjacent to the chase and on both sides. This causes problems in the spring
when the ice melts and water runs towards the window frames. By this time the soffits are completely plugged off for several feet.
I have taken down some soffit and the temperature on the plywood on the side of the chase was 15C (60F) after several hours running. I haven't got my head around the science but obviously condensation then freezing happening in that space. Running with the soffits removed seem to be the best short term fix although I still get some hoar frost forming.
Last spring when I was investigating this I found the preexisting fresh air vent to the original wood burning fireplace. I assumed I was drafting warm air
up to the soffit area so I blocked that off as best I could. Maybe I need to do more there.
I would appreciate suggestions. Google has not been my friend on this.
Would insulating the exposed sides of the chase be enough?
p.s. I just checked, the fireplace hasn't run since last night and with an ambient temperature of -20c the area of the chase under the soffits is -2c.
Tony
Tony
