My mouth is wide open and shut at the same time.That is a very interesting opinion.
If you can make a 95% worn down chain as sharp as a brand new, there is a reason (or "two") it might cut faster than a brand new one.First of all there is an increased space between the gauge and the cutting edge, that will allow more chips and dust transport. Also the chains is lighter, and I am not sure if a chain can be sharper than when hand-sharpened with a light hand and a brand new file. I think the the main reason we fail when handsharpeing is that we are not perfect on all different angles, and adjusting the gauge. Also very important to make both left and right side teeth exactly equal in angles ant tooth length, otherwise we lose efficiency, and the chain will act like dull faster. If you cut into a rock or a nail, it is usually only one side of the chain that gets dull, but you need to cut down both sides to equal tooth length.Even though there are posts from people who say they can get better performance after they sharpen a chain with X method, I have never, ever found that sharpening by any method will ever get a chain as good as it was brand new.
When sharpening .404" pitch chains for harvester heads, we use high speed robot machine grinders. But there is a problem with that. If you cut too much material the link get overheated, gets blue and the hardening is gone. But if a coolant is used, (we just let some water sip over the tooth while grinding), you can be pretyy tough cutting off the damaged part of the teeth. We used water on all grinder sharpening.I also find that if you hit anything other than wood with your chainsaw, a hand file is really hard work to bring the chain back to sharp and you really need an electric wheel or rotary.
Try the Granberg File N Joint. It definitely beats hand files and the Dremel, and I can honestly say the chains are sharp as new. Timberline gets great reviews but I wasn't willing to spend $100 on it. I got the Granberg for $35 off amazon and if you already have the files you're all set. It takes a few sharpenings to get the hang of it, but once you do, it's quick and easy, and most importantly, super sharp. I've been using it with milling recently and it's nice because you can sharpen the chain on the bar out in the field.Even though there are posts from people who say they can get better performance after they sharpen a chain with X method, I have never, ever found that sharpening by any method will ever get a chain as good as it was brand new. I've got files, file guides, electric sharpener, rotary sharpener, everything except a Timberline, which I think is way overpriced. I've taken my chains to the best shops to sharpen and it's no better than I can do myself.
If you own a proper sharpener, a new chain is not ready to use, but it is a good starting point. Use the Granberg and put a good edge on the new chain before you even start to use it.
See Akkamaan's thread hereI can't imagine needing to sharpen a new stihl blade out of the box. Other off brands, maybe. But why in the world would you waste the time and remove material from the cutter of a new, factory precise chain? Makes no sense.
https://www.hearth.com/talk/threads/is-there-a-reason-to-sharpen-a-brand-new-chain.143444/
It seems that Stihl specifically is calling out a tooth profile that does not match the factory profile. A new chain may have that odd profile for the simple reason that it is easier to achieve quickly with the factory tools than the rounded shape with proper tooth exposure that they tell you to get when you dress up a chain. Manufacturing methods almost never achieve optimum conditions but instead achieve conditions the high volume, rapid tools can accomplish. I would use a file on a chain for the same reason that a new knife always sees a steel before I use it. I like sharp tools.
You're suggesting people should "sharpen" brand new chains?
Is this the one you use?
http://www.amazon.com/Granberg-Bar-Mount-Chain-Sharpener-G-106B/dp/B0002ZY1WG
After years of trial and error, I can say that I can hand file to a like new sharpness, and I sharpen my blades on the saw. Nothing that complicated, I've taught several people how to do it, with a simple round file and holder that has the angles marked on the plate.
My fundamentals include: 1. Tighten the chain, tighter than normal before you begin. I tighten mine usually as tight as I can but still able to rotate the blade by hand. This stops deflection and tilting of the blade in the bar when you're pushing the file. 2. Chucking the saw up in a vice, with the bar and chain perfectly horizontal. I have a big vice mounted on a hydraulic lift table that allows me to put it at an ideal height for me. 3. I always count my strokes, usually 3-4 per cutter on average. I do all the right cutters, then spin the vise around and do the left. I use a simple Stihl round file holder. 4. Lastly, I only hit my depth gauge's every 5th time I sharpen on average, and check them with a depth gauge tool.
By having my saw chucked up in a vice, and adjusted to an ideal, ergonomic filing position,with all my angles set and the bar perfectly horizontal, I'm able to put ideal, consistent strokes on each cutter.
Not that exotic, but I can keep a new blade cutting ribbons for a very long time, and take an old blade back to like new.
Lastly, I can sharpen a blade with this system in about 5 minutes. And, it's always easier to keep a new blade like new than it is to allow an old blade to get really dull. I usually touch mine up every other tankful as a rule. When you keep them this sharp, you can really feel each cutter, and tell if you have one that needs a bit more attention, just by the sound/vibration of the file going through.
Yes, you should touch up a new chain. You can definitely feel the difference.
