OK- have been having some minor problems with Harman Accentra, but able to figure them out with some help. Today, it was going well (cleaned it yesterday). It had a good fire, then went into cooling mode. It did not start back up. I tried to start manual- nothing at all. Ten, it tried to start, but auger sounds like it might be working hard- took all pellets out- vacuumed out the feed pot- I can see nothing, but there is only a small part of the auger that I can see. Took back cover off- can't see that the chain is kinked, off. Tried to turn it on- I don't know how soon the auger should try to drop pellets after you turn it on. About 5-10 minutes after turning on, auger turned, slow/begrudgenly= nothing. The distribution blower light is not on when I first turn the unit on- should it be? I see where the distribution blower is- left lower side in back, as you look at it- is there anything I can do to check this? Also, on the left side of the back, are two wingnuts- what are they for? I can't find anything in the poorly instituted manual. Of course, it is Friday nite, dealer is 4 hours away, it's supposed to be in single digits at nite- house is about 50 degrees now. Hope somebody is awake on this forum!! You may email, if you wish- ohtoremember@yahoo.com Thanks
