With some advice from Wet1...I'll look into the used pro saws. Seems those may be a bit beefier than the homeowner Stihls. If I go new, I'll probably look into the MS250 and the like.
The 290 is a midrange saw 57 cc and will last a wood scrounger 2 life times if taken care of. The problem with a used pro saw is just that, it more than likely seen pretty heavy use. Buy new one time and forget about itSkier76 said:With some advice from Wet1...I'll look into the used pro saws. Seems those may be a bit beefier than the homeowner Stihls. If I go new, I'll probably look into the MS250 and the like.
Wet1 said:Agreed, although I wouldn't say pro saws on the used market have more than likely seen heavy use or abuse. I've bought dozens that have been very well maintained and/or have had an easy life. I'd guess most pro level saws aren't in the hands of daily loggers.
The downside to the homeowner grade saws (IMO) is they typically are heavier and have less power then their pro counterparts. Also, a basic or complete rebuild is cheap and easy on a pro saw should you ever have to do so for any reason... the same cannot be said about most HO grade saws.
With Skier's current needs, I suspect a HO grade saw will serve him well. I just prefer to buy good tools and buy them once. I also suspect he's going to do more wood processing in the future than he currently is. I know I remember picking up a piece of pine here and there as well and thinking my 60cc Homelite was all I'd ever need... and I'm sure you went down a similar path Smokin before you ended up with the 260/460.![]()
Skier76 said:Wet brings up a good point. My current firewood needs/wants will probably change. Maybe down the road we'll get an insert for the house in CT as well. Maybe I'll befriend someone who runs a tree service...you just never know. I know that I could probably get a "so-so" saw and be happy with it...if nothing ever changed.
ilikewood,
I saw (no pun intended!) that one too. I'm kinda thinking once I hit the $300 mark...it may make more sense to just go with new. Who knows though...I'll probably change my mind again. HA!
ilikewood,
Skier76 said:I went to a Stihl dealer today after work. I don't exactly like this place (I had a bad experience with them mounting ATV tires for me) so I figured I would go there, handle some saws and no one would bother with me. Basically, that's what happened.
I guess I'm kinda torn between the MS250 and the MS290. The Farm Boss was actually cheaper. However, it was heavier...but it does have a bigger engine. I think the 250 they had the ez start thing, 18" bar and tool less chain adjuster.
ikessky said:You guys need to hit the weights a little bit;-P I've run my 290 for hours at a time without much fatigue. I'm a pretty decent size though.
mike1234 said:ikessky said:You guys need to hit the weights a little bit;-P I've run my 290 for hours at a time without much fatigue. I'm a pretty decent size though.
Ouch, that hurts. :coolsmirk:
I figured you could probably handle it! ;-)mike1234 said:ikessky said:You guys need to hit the weights a little bit;-P I've run my 290 for hours at a time without much fatigue. I'm a pretty decent size though.
Suck it up, Buttercup! Back when I worked clean-up on pipeline hydro-testing, I carried my 16-17 lb R420 for 12-16 hours every day.mike1234 said:ikessky said:You guys need to hit the weights a little bit;-P I've run my 290 for hours at a time without much fatigue. I'm a pretty decent size though.
its that power head weight only?LLigetfa said:Suck it up, Buttercup! Back when I worked clean-up on pipeline hydro-testing, I carried my 16-17 lb R420 for 12-16 hours every day.mike1234 said:ikessky said:You guys need to hit the weights a little bit;-P I've run my 290 for hours at a time without much fatigue. I'm a pretty decent size though.
I don't really know what it weighs. I just googled and found a spec that said 16.5 lbs with B/C. Not sure if it includes gas and oil too. You know how they take liberties with the specs. It's a mostly metal 65cc saw. Probably explains why my knuckles drag on the ground.smokinj said:its that power head weight only?
LLigetfa said:I don't really know what it weighs. I just googled and found a spec that said 16.5 lbs with B/C. Not sure if it includes gas and oil too. You know how they take liberties with the specs. It's a mostly metal 65cc saw. Probably explains why my knuckles drag on the ground.smokinj said:its that power head weight only?
mike1234 said:If I didn't like my Stihl dealer, I would buy something else. You might not need them much, but for new chain, or a new bar, or maybe some advice on something, you will be talking to them.
Both of these saws will get bogged down at times, as will all saws of this range. One way to combat that is to buy the smaller bar, 18 or even down to 16" will help with that.
For me, My 290 is about equal to my 270. The 290 is heavier, much heavier, and actually it has lower rpms than the 270. I've done some work to both of my saws, but before I did, the 290 seemed like the better saw, now the 270 is my favorite hands down, mostly because it is so much lighter.
If you don't need a 20" bar, the lighter saw may be your best bet.
thinkxingu said:Hello There,
It's not necessarily about being strong: I'm 5'7, 260 pounds and can bench press 325 and squat 415, but I still choose to work with lightweight tools, equipment, and materials when I can. My hiking gear is all ultralight, my tools are all lithium-ion, and I chose the MS250 because it's light and easy to maneuver.
Would the 290 be a bit more powerful? Maybe, but the 250 is more comfortable and, for scrounging a few cords a year, as effective. No need to get saw envy here!
S
