Well I have gone through 150 bags to this point and am going to try the leaf blower out tomorrow. Got the wife on camera - video to follow :D
ResOps said:Well I have gone through 150 bags
ResOps said:Zeta - I do a thorough cleaning after
every tonne but I haven't done the pipe yet..
ResOps said:Well I tried the blower trick and must say .....it's not gonna be the end all for me. After running it I performed my 1 ton overhal and took a few picks of what was left inside as well as a video of what came out with the blower. Pics tonight![]()
They don't.pelletizer said:I don,t get it why should these stoves and vent pipes have to be cleaned out so much after a ton of pellets,
CZARCAR said:....been adding dry laundry detergent in my englander 25 which burns pellets & coal. when i spray water on the hot glass to clean it, the detergent seems to make it work better= hoping it affects the blower blades as well.
zeta said:pelletizer said:I don,t get it why should these stoves
Huh? The OP went through 3 tons not 1.
firewarrior820 said:Well I tried the blower trick and must say .....it’s not gonna be the end all for me. After running it I performed my 1 ton overhal and took a few picks of what was left inside as well as a video of what came out with the blower. Pics tonight post#16zeta said:Huh? The OP went through 3 tons not 1.pelletizer said:I don,t get it why should these stoves
ResOps said:firewarrior820 said:Well I tried the blower trick and must say .....it’s not gonna be the end all for me. After running it I performed my 1 ton overhal and took a few picks of what was left inside as well as a video of what came out with the blower. Pics tonight post#16zeta said:Huh? The OP went through 3 tons not 1.pelletizer said:I don,t get it why should these stoves
it's all the answers in quotes that get confusing...
1) I have gone through 3 tons of pellets so far this year
2) it was time for my 1 ton cleaning as recommended by my dealer
3) I decided to try the leaf blower on this cleaning to perform said 1 ton major cleaning
As cleared up above I tried the leaf blower at my maintainance interval that is recommended by my dealer to keep the stove operating efficiently. Again I guess if I cleaned the stove out first then used it there may have been better results but that defeats the purpose of me using it. I guess I misunderstood the idea -thinking it would pull all loose debris away.
Anyways I got another ton in the laundry room and the stove is cleaned and purring away, which is good seeing as how it's -25 deg C. or -13 deg F. here this morning.
ya its cold up here :bug:
pelletizer said:ResOps said:firewarrior820 said:Well I tried the blower trick and must say .....it’s not gonna be the end all for me. After running it I performed my 1 ton overhal and took a few picks of what was left inside as well as a video of what came out with the blower. Pics tonight post#16zeta said:Huh? The OP went through 3 tons not 1.pelletizer said:I don,t get it why should these stoves
I just had the impression a lot of people were doing a clean out after 1 ton so I did too,
I was surprised at the amount of dust in the pipes, Not sure if I have mastered this Quote capture thing either sometimes it works sometimes not?
ResOps said:pelletizer said:ResOps said:firewarrior820 said:Well I tried the blower trick and must say .....it’s not gonna be the end all for me. After running it I performed my 1 ton overhal and took a few picks of what was left inside as well as a video of what came out with the blower. Pics tonight post#16zeta said:Huh? The OP went through 3 tons not 1.pelletizer" date="1231658469 said:I don,t get it why should these stoves
You got the quote thing down Pelletizer. What does your dealer recommend? I guess it's up to the owner to adjust this to his burning rate, pellets and past cleanings to determine what's needed - as you mentioned there was alot of dust so maybe it was time. ;-) cheers Res
