Unit is less than a year ld. Customer called and said stove popped and shut off completely. Customer checked or took circuit board out and said it has a large burn spot on it. Antbody have any insight or has anybody experienced this before??
???check the igniter...and the wires going to it, perhaps the ash pan scored or got hung up on a wire. The older versions had ceramic nuts that would come off and the wires would short out on the stove, such is not the case if it is a newer one. IF THE CONTROL BOX SHORTED OUT FROM WITHIN AND THE BOX WAS OPENED...THE BOX WILL BE VOID FROM WARRANTY. There is a fuse in the control box. Perhaps that is the thing that popped and repalcing that fuse will solve problem.
