Got the new probe in Friday, it appears to be reading the same as the other on the last burn.
Started a fire Sat evening around 7, top down with 4 splits. Once the fire was going good, shut the shotgun air and dropped the main air half way. Once the wood started coaling good, loaded the stove loosely, opened the main air all the way and let the new splits get a good burn. Shut the main down about half way for a few minutes, and then all the way down. A little bit of flame and then just glowing. Probe temp got up between 1800 - 1900. Woke up about 12:30 inside temp was 78 and checked the fire and probe was around 1200. Had heavy coaling, and spread everything out to fill again. Filled tightly this go round, and as before let the wood get going good before shutting the air down. Watched it for bit, and probe went back up to 1800. Temps outside at start were in the high 30's.
6am temp was 77 and probe was at 1200 and still had solid fuel on the sides and towards the back with big coals in the middle front. Temp outside was in the high 20s. Was going to let it go for the day, but decided to put 2 - 12" 4x4 pine scraps in a couple hours later. Let it get going and shut the air down again. Probe got up to 1600, but through the day it was in the 1000-1200 range. Raked the coals a couple times during the day and inside temp stayed at 77 most of the day. Outside temp got up to mid 40s.
5pm had a nice bed of coals. Cat probe was at 800. Put in some thicker pieces of kindling and 4 splits on top. Both air controls open until a good flame going then closed shotgun air. Loaded the stove and let it get going good. Closed air down 1/4 let it burn some more then closed it 3/4 down and finally all the way. Cat temp moved up quickly and looked like it was going to peg out again, but stopped just past the 2000 mark and then settled down at 2000 after a few minutes. Inside temp jumped up to 81. Cat stayed around 2000 for a while and then dropped to 1600. At about 9mp it looked like the wood was being consumed faster than the night before so I added 3 splits and after shutting air down cat went back to 2000. Fell asleep, but woke up about 12. Cat had settled down to 1500, inside temp at 76. 6am still had some small hunks of wood that were still burning, the rest was coals. Temp inside was still 76 but dropped to 74 a couple hours later. Outside temp was to get into the high 50s, so didn't reload the stove. Opened both air controls to help burn the coals down.
The first burn was good, put out steady heat and lasted longer than I expected. Thought adding the 4x4 scraps would make it burn quicker, but seemed to help longevity of the burn? Second burn I think I added the new splits too soon and didn't let the starters burn down far enough. This is similar to what I've done in the past when the cat has gotten hot, and assume it's due to too much off gassing at once?
It appears that adjusting the air control plates has made some difference, and maybe still new overactive cat since I'm not burning continuously? Attached some pictures as maybe they tell a story about how I'm burning that someone can interpret. I understand the darkened glass is due to low burn, but looks like one hot spot in the middle. That is where the shotgun air control is and it has 2 holes drilled in the plate as compared to one in the primary control plates. I may try to play with blocking off one of the holes or part of one and see if that makes a difference.
![Buck 91 Help me understand my first burns Buck 91 Help me understand my first burns](https://www.hearth.com/talk/data/attachments/287/287875-4fa83f9c78af7604c2200536bde3f832.jpg)
![Buck 91 Help me understand my first burns Buck 91 Help me understand my first burns](https://www.hearth.com/talk/data/attachments/287/287872-b524704146f9ad7249bae87cfd80a4c9.jpg)
![Buck 91 Help me understand my first burns Buck 91 Help me understand my first burns](https://www.hearth.com/talk/data/attachments/287/287873-34445394005b6360fb5cc6bb5c2a1101.jpg)
![Buck 91 Help me understand my first burns Buck 91 Help me understand my first burns](https://www.hearth.com/talk/data/attachments/287/287874-60db12335c58d61b440485620948652c.jpg)
