I Built a Firewood Calculator (total cordage, cu/ft, weight, BTU and more)
BCB
32
Quebec
boisafeudunord.com
I have built a firewood calculator and hopefully some of you might find it useful, it is a bit different from others I have seen so far online.
  • Calculates total cordage based on woodpile size as well as total cubic ft. Cordage is outputted both in cord and face cord as both are widely used depending on area. It also shows aliases for both cord types for example a Face cord is known as a "Rick" in some places and a cord can be known as a bush cord or standard cord.
  • Gives an estimate on weight depending if you chose dry or wet
  • Gives estimated "Heating Energy" (BTU) as well as equivalent in electrical (kWh), and heating oil (gallons). This is also dependent on whether dry or wet as BTU changes substantially.
  • Fun random firewood fact displayed at bottom on each calculation.
Hope you find it useful: https://boisafeudunord.com/tools/cord-calc.html
Appreciate feedback, and if there is something you think should be added, let me know.
[Hearth.com] I Built a Firewood Calculator (total cordage, cu/ft, weight, BTU and more)
Reactions: djlew
The calculator has been used 500 times in the last 24 hours, great to see!
Few more things incoming:
- Option to use it in "stack" mode or pile mode for loose piles.
- Switch between metric and imperial
- Some more wood types to add
- In stack mode options to set number of rows and gap size.
- Option to set wood stove / burner efficiency %.
There is now a new version available:
- You can switch between Metric and Imperial
- Set burn efficiency
- More wood types added
- Bunch of small fixes, some organizing the layout, top menu improved for mobile
- API moved to a bigger server
Have a safe and happy holidays!
Reactions: AstroBoy
