MSG,
Just curious on how your making out with the stove?
Hopefully its keeping you warm enough too!
jay
jay
jtakeman said:MSG I feel you pain! I had a 70K BTU wood stove. Doing all the math and asking several stove and HVAC guys. They recommended a 45K to 50K BTU pellets stove.
1st I replaced it with a 44K BTU Quad. House never felt as warm as the wood stove but heat was more consistent(and I didn't have to load the wood in early am.) We ran that stove for 9 years or so and only suffered on the extremely cold days. I would have to fire up the wood stove to help out the pellet stove.
My second stove was a 55K BTU Breckwell bigE and it just didn't perform the same as the Quad. We felt cold even on the 30º days. We only ran this stove for 1 1/2 years and could not stand it.( still trying to sell this one)
My 3rd stove(present) is a 60K BTU Enviro Omega. This stove was the ticket. We feel very close to the warmth as the old smoke bellowing wood burner. And I am using less pellets with this stove too. Due to a better designed heat exchanger. More heat in house-less heat out the flue.
My suggestions would be to add an OAK and reduce the size of your flue to 3 inches if you can or 4 inches max!(6 inches is to large for high altitude). If no change? Then you might want to get some more BTU's from a larger stove! Slide a P68 or an Enviro Omega in there! Bet you'd feel warmer then.
just my 2
jay
buildingmaint said:jtakeman said:MSG I feel you pain! I had a 70K BTU wood stove. Doing all the math and asking several stove and HVAC guys. They recommended a 45K to 50K BTU pellets stove.
just my 2
jay
How come you can't sell your BIG E , I'm sure some one would buy it for the right price .
no pane said:big e @ the box stores around here sell for $950 brand new(on sale)
no pane said:http://www.fleetfarm.com/mff/browse/productDetail.jsp?productId=0000000003067&categoryId=00249&navAction=jump
no pane said:didn't mean to offend
please accept apology
! But you could send me some cheap prices. I only wish I could get things as cheap as you!MountainStoveGuy said:LOL wern. Do you know how wood stoves are rated? They are rated in MAX btu.s They put out zero when cold, and max when fully loaded burning hot as possible. Take a 12 hour cycle, average that out and tell me what you get. My math tells me that is 50/hour average.
1=0
2=40
3=70
4=80
5=80
6=70
7=70
6=60
7=50
8=40
9=30
10=20
11=10
12=0.
This is how i burned my wood stove. I work and sleep, no time to keep the fire going at max potential. Post something constructive and prove me wrong, instead of insulting me. For people that have moved from wood to pellet, i do not think my findings to be that uncommon.
I have burned both. The pellet stove has not shown me anything to write home about as far as its heating capacity, and pure convection does not heat as well as a mix of convection and radiant.
stoveguy2esw said:honestly , i burned a 2000 ft rated cat stove for over a decade in my house, i needed it back when we bought th eplace , little insulation , single pane windows and leaks galore, i swittched to pellet cause my spouse couldnt build a fire in a woodstove with a gallon of napalm and a gun to her head, so i bit the bullet and went to pellet , it does a great job but then im not having to push the stove at all in my house now , (added insulation , working on window replacements currently. i like the pellet stove for its versatility i can control the heat output easier than i could with the woodstove.
i still stick to my theory about altitude affecting realized heat output differential between radient and convective heat sources though.
iceman said:looks like MSG left us for dead!!
