About 10 years and 60 or so cords of mid Kentucky hardwoods, dropped and bucked with my 359xp. No complaints at all. Ran it almost non-stop for three days after the '09 ice storm, never a hiccup.
ironpony said:fyrwoodguy said:best 60cc saw out of the box yet,only time will tell. standard 3/8's pitch large chisel cutter saw chain.
346XP new edition 50cc saw small .325 pitch small chisel cutter saw chain,best ever- soon to be discontinued-
is that one of them new chinese knock offs???
HittinSteel said:ironpony said:fyrwoodguy said:best 60cc saw out of the box yet,only time will tell. standard 3/8's pitch large chisel cutter saw chain.
not quite
fyrwoodguy said:346XP new edition 50cc saw small .325 pitch small chisel cutter saw chain,best ever- soon to be discontinued-
deranged said:fyrwoodguy said:346XP new edition 50cc saw small .325 pitch small chisel cutter saw chain,best ever- soon to be discontinued-
ARgh, say it aint so. Just when I have the next saw picked out...
HittinSteel said:deranged said:fyrwoodguy said:346XP new edition 50cc saw small .325 pitch small chisel cutter saw chain,best ever- soon to be discontinued-
Not to worry, here's its replacement. Click a few to the right and you'll see the 543XP, which will probably be a little light sabre like the 242XP was.
http://www.husqvarna.com/dk/forest/products/xp-saws/550-xp/
bogydave said:Husqvarna 357XP/359 are the same owner's manual. Big price difference. Pretty close to the same saw.
Part:
(broken link removed to http://www.husqvarna.com/ddoc/HUSI/HUSI2001_AAaa/HUSI2001_AAaa__1062606-62.pdf)
For me it was between the 460 Rancher & 359, I got the 359.
Haven't ran it through it's paces yet, 2 gallons thru it. Sure an upgrade from my 30 yr old Husq 61.
Happy with it so far.
amp said:bogydave said:Husqvarna 357XP/359 are the same owner's manual. Big price difference. Pretty close to the same saw.
Part:
So is there a lot different between the 357xp and 359? Looks like the 359 is 59.0cc / 3.9hp and the 357xp 56.5cc / 4.4hp. I would guess the xp has the metal crankcase. I'm also guessing this would cut a bit easier (no bogging down) compared to the 346xp or 350 I used?
MasterMech said:amp said:bogydave said:Husqvarna 357XP/359 are the same owner's manual. Big price difference. Pretty close to the same saw.
Part:
357XP is the next step up from the 346XP. The 350 doesn't even play in the same league as the 346XP once you get your hands on it and sink the bar in a log. If you're looking at the 357XP you should know that one, it's on that soon to be discontinued list and the 562XP is it's replacement and two, the Stihl MS361 or MS362 are a bit more saw for less $$ in stock form. Once the mods begin for the 357XP tho, all bets are off!
Part:
Part:
I’m guessing you mean that the 350 doesn’t even play in the same league as the 357XP. I only say that because the old 350 (now 450) is really not that different from the 346xp.
They cut about quickly as each other and they both bog down just a bit if you accidentaly push down into the wood too much by accident.
mayhem said:I’m guessing you mean that the 350 doesn’t even play in the same league as the 357XP. I only say that because the old 350 (now 450) is really not that different from the 346xp.
Again, close to 20% difference in power output between the 450 and 346. This is like saying theres not much difference between an V-6 Mustang and a GT. Its a completely different saw.
Have you used both of these saws in back to back cuts? I just really find it hard to swallow this statement but I have to be fair and no, I have not used both of them personally. I have used a 455 Rancher back to back with my 359, both 20" b&c with fresh chains in 15" red oak (same log). Not quite a 10% difference in power rating according to Husky's website and it was night and day between the two. The 359 ate the 455 for breakfast in the cut and it was noticably lighter to boot. Any saw can get bogged down in the cut if you push hard on it...in my test the 455 bogged much easier than the 359 ...just took a light push in the middle of the cut and it would grab, the 359 could get bogged at the same point, but you had to want to do it.
If you've done this cutting yourslf I'm thinking there was something wrong with the 346 you were using, can you tell us more about how you did the testing? The difference between a 450 and a 346XP should be VERY noticable.
At any rate, for the type of work you're describing way back on page 1, I don't think a 50cc saw if the best tool for you, ou'll be a lot happier with a 60cc saw, a 70cc saw like the 372XP is what a lot of people seem to really like for long term, heavy use for land maintenance and heavy firewooding...but the budget's got to stop at some point.
Just my 2 cents.
KodiakII said:HittinSteel said:deranged said:fyrwoodguy said:346XP new edition 50cc saw small .325 pitch small chisel cutter saw chain,best ever- soon to be discontinued-
Either a 357 or a new 555 and you'll leave the others behind in a pile of saw dust! :cheese: I was going to p/u a 555 this weekend, but I put my back out the other night at work...need to let it heal, and don't need a new saw staring at me all weekend...taunting me! :gulp:
Sawmillman said:Husky vs. Stihl... Id say for you it would be the one with a honest close by dealer.For me that means husky, been running them just about 30 years and have been buying my saws at the same place.Good service no exuses,no wating for parts.I run a 372 most of the time good power to weight ratio,balance is reasonable, it runs a 24" bar ok and you can work with it all day with ease."Homeower" saws are really meant for ocassional use, and will wear you and themselves out.I would recommend a bottom tier pro saw in a Husky that would be s 365,( and even this wont really do well with a 24" bar).Try some out at your dealer see whats feels right for you,and get him to cut you some slack on the new chaps and hat ;-)
)on a diaster relife team here in MA. and what a sweetheart much better than my Husky 372....That 2171 was bought for 650 then ;there was a special promotion....Sawmillman said:I did run a jonsered 2171 this past june (it was brand new)on a diaster relife team here in MA. and what a sweetheart much better than my Husky 372....That 2171 was bought for 650 then ;there was a special promotion....
KarlP said:Sawmillman said:I did run a jonsered 2171 this past june (it was brand new)on a diaster relife team here in MA. and what a sweetheart much better than my Husky 372....That 2171 was bought for 650 then ;there was a special promotion....
I'm curious what is "much better" than the 372? Thought it was same saw with a straight handle bar, different color, and different stickers.
I bought my dad who was giving me lots of free firewood a 372 for $530. Of course that was the 2nd or 3rd time (of 7 or 8 now) they were discontinued. LoL
Every size saw has one thing it is ideal at, but they will usually work for bigger/smaller stuff as well. I could buck 30" rounds with a 40cc saw, but it would wear me out. I could limb a tree with an 80cc saw, but it would wear me out.
