So a while ago I got taken on Craigslist for a chainsaw. Knew I was going to need one soon at least once, but didn't really know what I was doing. I use the word "taken" because the guy that sold it to me sent his wife to do the deal in the parking lot while he hid inside the building. I saw them get together and leave as I was pulling away. The saw sat for at least 2 years in my possession. She fed me a story about it leaking because he just filled the oil, but had no other information. I bought it, hook, line, and sinker. I didn't pay much for it, probably less than $100.
Someone came to help me use it and he determined it needed sharpened. I had purchased the Chicago Electric sharpener model and stumbled our way through it. Even after that, he said it just wasn't cutting like it should. Upon further inspection, it was out of bar oil. Whoops.
I took it to a shop to have it sharpened by someone with experience and after putting oil in it, showed me it was leaking, and the oil seal was bad. Also showed me a mark on the bar which indicated someone had dropped it, and then flipped the bar to move the damage mark to the top.
He could fix it, but would charge me more than it was worth, and encouraged me to do it myself. "If you can sharpen a blade, you can change a seal."
This is a 55 Rancher which is a discontinued model. I really only need it for a medium sized job with some oak chunks. After getting some oil in it, he said it is a good running saw with a sharp blade and just needs some love if it is going to be kept around. I am currently looking at some replacement parts at hlsproparts dot com(not sure about links here), like an oil pump and replacement gaskets.
Now, in theory, if you are going to do it, it should be done right and replace the spark plug, muffler, bar, lynch pin for safety brake.
Now, should I spend the money to fix the oil problem, or should I just invest my time and money into a new or trusted used saw? The gasket set is $9 and the oil pump is $7. That would at least get me going to finish the job. Yea, it's only $20-25 + shipping + time, but if I am fighting an unwinnable battle it would be best to invest those efforts into something else.
Sorry for the epic story.
