Hey guys,
I have a 460 Rancher that is about 8 months old. About a month ago while using it, it started reving high at idle and wouldn't slow down. I took it to the Husky dealer where I bought it and they looked and couldn't find anything wrong, so they adjusted the carb and called it good. So I took it out for the first time since they looked at it and I had a fairly large fir log that was bigger than the 24" bar, so it was quite a workout for the saw. I cut a couple rounds and as I got to the bottom of the third cut the saw bogged down like it was pinching so I pulled the saw out of the cut and it started revving higher than I can rev it with the trigger. I stood there for a split second and hit the kill switch and the saw WOULDN'T DIE
It continued to rev really high for probably a second until it finally shut off and started winding down. I didnt run it again. I took it back to the shop and told them what happened, the mechanic told me the saw was running really lean and the plug was so hot that when the electronics were turned off the fuel supply was still burning. Again they couldnt find anything wrong with the saw other than they gave me some BS about a curly-Q in the fuel line blah, blah, blah. They said the compression was fine and nothing was hurt. I haven't run it since getting it back, so what do you all think or suggest.
Thanks RL
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks RL
