Huskee 22 Ton Log Splitter Review
leeave96
1,113
Western VA
I've been absent for a while frying other fish, but I thought I'd post a review of a Tractor Supply Huskee (SpeeCo) 22 ton log splitter I recently bought.
I've run about three tanks of gas through the splitter and so far so good. I was concerned a bit about the 22 tons vs 35 ton splitters I see and the cycle time. I've read posts about both and wondered if the splitter would be under powered and slow. Honestly, I have yet to stall the splitter. I've got oak, locust and they are pretty easy. Cherry and knotty pine are the hardest to split - but the splitter does very well. As far as cycle time - I was surprised at how quickly the splitter runs. I'm not selling wood, only splitting it for my own use and the speed/cycle time is not a problem. If anything, I can't keep-up with it.
The engine sets nicely out of the way and the beam easily tilts-up for vertical splitting.
The one accessory I am going to get is the table that bolts to the beam. When I am by myself, that table would be the extra set of hands I need to handle a larger split - after I split it.
The price - $999 plus tax. I bought it at Tractor Supply and though it says Huskee on the beam, it is a SpeeCo brand.
All in all - for the homeowner like me, I'd recommend this splitter.
Bill
I am still young, 27, and I enjoy splitting wood, but I have often thought about getting a splitter. I would probably buy something similar to what you bought, as $1000 would be around my price point.
My question though, which may be hard to answer, how many years useful life would I get out of that splitter? 5 years, 10 years, more? I process about 5 cords a year.
Glad you like it, I almost bought one but found a new Swisher for $450 in Rhode Island, so I picked that up Saturday, have yet to try it. It only splits vertical but for the price I couldnt turn it down.
Backwoodsavage is the design engineer for the company.
True, just ask him. :)
What's the splitting force?
jwoair23 :
" how many years useful life would I get out of that splitter? 5 years, 10 years, more? I process about 5 cords a year."
At 5 cords a year, I'd guess an easy 20 years + with proper operation & maintenance.
I have the same splitter, well mine is a 22 ton Speeco.
Well made, heavy duty steel, good welds, nice beam & wedge design.
Things can break & wear out even on more expensive models.
I figure mine to last until I no longer split wood. When I got it, I looked at major repairs: maybe a new engine or valve or pump many years down the road & maybe "O" rings, a hose, starter rope etc. for minor fixes. The splitter itself will out last me. I keep it clean, wiped down with an oily rag on the beam every now & then, kept in dry storage, run at 7/8 full throttle & if transported down the road it goes in a trailer.
For the money, it's the best splitter I looked at. IMO
I don't know if there is a few minor differences between the Tractor supply Huskee & the Speeco.
Mine has a Honda & the Huskee maybe a Briggs.
Over 20 cords so far & has split everything I've put on it.
Glad to hear you like your splitter, I love my Huskee 22ton splitter! So far it has run great and been really reliable. I would guess between my dad and I we have split close to 20 cords with it and I see no reason why it wouldn't last my lifetime with some maintenance. Heck if the engine ever blows up I'm going to buy the Harbor Freight knock off Honda replacement motor for it. I put that engine on my troy bilt Horse tiller and it runs awesome.
I wa s going to ask him where I can get a comfortable milk crate for splitting :)
Its a 12 ton, might be all I need, my 5 ton electric was doing 95% of what I needed so I cant imagine this one doing any worse.
K
FYI, through a couple of calls to speeco, I found out that BS builds that engine to their own specs. Weighted flywheel and short shaft (2.75", I believe). The blower housing on my rattled apart, and I called them for some ideas, and the aftermarket engine possibilities. I suppose you could try to whack the shaft with a cutoff wheel. It just gets a lovejoy on the end, so it doesn't have to be perfect.
I have split 30-35 cords with it. It has split just about everything I have asked it to. I didn't like having to fix it at this point, but I guess 'you get what you pay for.' You aren't going to get a better one for $1000.
"FYI, through a couple of calls to speeco, I found out that BS builds that engine to their own specs. Weighted flywheel and short shaft (2.75", I believe). The blower housing on my rattled apart, and I called them for some ideas, and the aftermarket engine possibilities."
Did they give you any ideas?
Nope. Never heard of that happening before Huskee 22 Ton Log Splitter Review
Nice review Bill.
jwoair, I believe there are 3 of us on this forum who have 20 ton splitters. Probably all are like mine with a 5 hp Briggs & Stratton engine. How long will the splitter last? I don't know, but so far ours has split well over 200 cord of wood and is over 20 years old. Still doing just fine.
Weatherguy, what on earth do you mean, "It only splits vertical?" That is all one needs! Milk crates are easy to find. You then just need a small cushion else your arse might end up looking waffled a bit.
BogeyDave, now you went and done it. You let the cat out of the bag. Thought I'd kept this a secret.
have the Huskee 22 Ton Splitter from TSC with a Briggs engine. Still splits good, but I have a slow leak in one tire and another slow leak on the gas tank. If I run the engine the leaks stops so I don't fill the tank all the way..
Sounds like a job for JB Weld. You can use the JB Water Weld for the gas tank. Won't work so good on that tire though...
Or just surf ebay for a new tank. Might cost less than a tube of JB Weld! ;lol
Slime/Tube/Plug the tire. Actually the whole tire/wheel assembly is usually available pretty cheap at TSC.
I put green slime in the tire a few months ago. Didn't work since its leaking from the rim. Have you or anyone else changed the tire on this splitter before?.. I notice the hub caps on the axle will need to be pryed off somehow. I'm hoping these caps are full of axle greases as well since my splitter has been sitting outisde most of the time (covered) but the tires are exposed to rain at times.
After I split another cord, I will remove the tank and see where the crack is. Anyone have the part# on the gas tank?
The BS site actually has a pretty decent parts breakdown. I looked up the numbers for a bunch of stuff on mine, and took my list to the local small engine place. Saved them some work, and I did it at home with a coffee, instead of leaning on the counter waiting for someone else to do it. Plus, I got the right parts.
I guess these don't have a 4 lug pattern to hold the wheel to the hub? So removing these wheels would be very similar to removing rear wheel hubs on a FWD car or trailer wheel hubs to re-pack wheel bearings. The grease cap can be removed via a special type of pliers, large channel-locks or my favorite, a cold chisel and a gentle hand. Use the chisel between the lip of the cap and the wheel hub to force it apart a fraction of an inch at a time. Work all the way around the cap and it will pop off in no time. Don't worry about screwing up the caps either, they're cheap and easy to replace, any auto parts store should have them in stock.
I'm just going by observation since I haven't removed a wheel on this splitter before: The bearing should sit inside hub which could be packed into the rim. Once the cap is removed it should expose a bolt or some kind of cottor pin setup to remove the wheel. Once removed, the bearing can be banged out from the hub. I'm not sure if a new wheel comes with a new bearing. I'm not sure if this wheel actually has a seperate hub because the actual rim could be the hub itself. I have no idea if there are racers that need to be banged out as well..
I just bought this exact same splitter 2 weeks ago at TSC. It was $899.
I have run it 4 times so far and have had no issues as of yet. It has started on the first pull every time too.
I am splitting mostly ash and cherry and while it has groaned a couple times it has had no issues with anything so far.
It says Huskee all over it but the oil filter says Speeco on it.
So far i love it.....
I am pretty sure that Swisher splitter is a 12 ton.
I almost bought it from The Sportsmans Guide but by the time i paid for shipping it would have been almost $800.
For another $100 i got a much heavier built Huskee 22 ton.
They are now sold out of those and its discontinued as well.
I was waiting for the Huskee to go on sale at TSC and this 12 ton came up for $450 so I jumped on it. I got it going last week, split some small rounds to get the hang of it then I took a knotty, gnarly round from some type of fruit tree and it split it no problerms, wish I had the option to go horizontal but Im not going to complain, can always sell it and upgrade some day if I want to.
The Swisher is a lot more sturdier than I thought from looking at it in the SG, its actually pretty stought.
Update - I bought the $50 log table for this splitter and have found it to be a great addition. It's nice to have a place for half a split while wrestling the other half.
Bill
Bill
Nicer yet and a whole lot cheaper is to use the ground for the table. Splitting vertical is the simplest and easiest way to split wood....if it is done right. Seems some have the wrong idea on how to do it vertically. Like most things, there are little tricks that make it easy.
Lol, I was waiting for this post......;)
I think it's time for Dennis to make a video on how to split while seated on a crate.
edit:....and after last night's splitting of large walnut rounds I really could use some of those "tricks".
Reactions: MasterMech
