DickRussell
While deliberately humidifying the air with some device will work, wanting to do only that ignores the fundamental problem. A house with very dry interior air in the winter almost always a house that leaks far too much air. Human activity (showers, breathing, cooking, plants, aquariums, etc) produces moisture, while cold dry outside air leaking in down low and out up higher flushes out that humidity. Too dry inside means too much air leakage. Leakage also creates draftiness and cold spots, making the house uncomfortable and harder to heat.
Long term, you ought to do what you can to tighten up the house. It's no secret that new houses built to be very tight also need mechanical ventilation, both to provide the correct amount of fresh air and to keep interior humidity down to a comfortable 30-40% RH, even in winter. However, air sealing an older house is unlikely to be able to tighten it up enough to the point where mechanical ventilation is needed. The house still will leak air in winter, just nowhere as badly.
A good article to read, along with the referenced "Related Articles" at the end, is found here: https://www.energyvanguard.com/blog/will-a-humidifier-hurt-your-indoor-air-quality.
Are they really as good as Edward Norton says thy are?
Manly
