How are the barefoots working for you.Kept the Big E on 3 all day, got up to 24 here today, currently 15 F outside, 71 inside...using 2 bags of Barefoot's a day
Wow you burn that much on a cold day? What power setting are you using and how many square feet are you trying to heat? My Palazzetti heating 1450 square foot 2X4 wall cape cod home, on auto power level 3 and has never used more than a bag a day.Below zero here on New Year's Eve, in mid-Maine. Stove on 3, burned 2 bags today. I expect to burn 2.5 bags/day for these real cold days thru Saturday. Interestingly, 2.5bags is roughly equal to 6 gallons of heating oil, which is what I used to burn on really cold days pre-stove.
Haha, for my stove to burn 1 bag a day, that bag would have to be 100 pounds! Anyhow, I've got 1700 sq ft of open floor space, but it's all vaulted, with the great room 26 ft high, so it's a lot of volume. Factoring the open loft, it'd be equivalent to well over 2800 sq ft lofted. Even where there are ceilings, like in the dining area, we're talking 10 ft high.Wow you burn that much on a cold day? What power setting are you using and how many square feet are you trying to heat? My Palazzetti heating 1450 square foot 2X4 wall cape cod home, on auto power level 3 and has never used more than a bag a day.
As warm as a bug in a rug !
My Harman does not care how cold it is outside, It keeps us at 76 all day long on less then a half a bag of hamers hot ones LIFES GOOD///////
Yes, Please, Stop buy and check it out, Ha ha .Do you live in a shed?
Lol, I will bring the beersYes, Please, Stop buy and check it out, Ha ha .
That's a lot of space for one stove to heat, now I see why you are going through more than two bags a day. How many BTU's is the Piazzetta putting out? Do you run in auto or a specific power level?Haha, for my stove to burn 1 bag a day, that bag would have to be 100 pounds! Anyhow, I've got 1700 sq ft of open floor space, but it's all vaulted, with the great room 26 ft high, so it's a lot of volume. Factoring the open loft, it'd be equivalent to well over 2800 sq ft lofted. Even where there are ceilings, like in the dining area, we're talking 10 ft high.
Edit: bad math the first time lolThat's a lot of space for one stove to heat, now I see why you are going through more than two bags a day. How many BTU's is the Piazzetta putting out? Do you run in auto or a specific power level?
Right now, it's below zero this morning, and the stove is running on Power5, which means about 5.7lbs/hr, or 47k btus. The stove initially only burned about 5lbs/hr, but small tweaks have upped the feed rate to its rated capacity. The stove has a thermostat, with what seems like a 2 degree swing. Once it gets to the set temp, the Power level drops to Power1, which is about 1.3lbs/hr. I used to run it on an energy saving mode, which would shut the stove down under certain conditions, but lately because of the cold, there's no energy saving mode possible!That's a lot of space for one stove to heat, now I see why you are going through more than two bags a day. How many BTU's is the Piazzetta putting out? Do you run in auto or a specific power level?
