This may seem like a dumb question, but how do you know if you are having a chimney fire? Besides that your house is on fire, obviously. Any tell tale signs to watch for?
atomichawg said:This may seem like a dumb question, but how do you know if you are having a chimney fire? Besides that your house is on fire, obviously. Any tell tale signs to watch for?
Franks said:"had"
ControlFreak said:Anybody have any pictures of the exterior view of a chimney fire? I hear that they can be spectacular.
Right. I only ever had one (that's one too many), and it was a small one. I could hear the rumble and roar and see dense black smoke from the chimney. Shut the stove up as tight as it could go and called the FD. The sound stopped after about 2 minutes, and by the time the FD got there, it was out for sure. They still came in and scooped the fire out of the firebox and took it outside, and ran a chain up and down the chimney to dislodge any big creosote chunks. Not much help in this particular case, but it's a good thing they were there just in case, I suppose.quads said:Depends on the size of the chimney fire. A small one might just sound like rain inside your pipe. A big one, you'll know it if you're home. It roars, shakes, deep red flames out the top of the chimney, column of dark smoke, soiled underpants. If you're not home, you may not even know you had one. Chimney fires don't always mean house fire.
firefighterjake said:How to know if you are "having" a chimney fire: Typically you will hear it -- sounds like a freight train or Boeing 747 about to take off . . . another tell-tale sign that you're having a chimney fire is when the firefighters begin climbing on your roof.
How to know if you "had" a chimney fire: Black ash and bits of creosote on the snow-covered ground, discolored metal pipe, very clean tile.
How to know if you "had" a bad chimney fire: You and your family are staying at Motel 6 while your old house is being rehabbed or your new house is being built.![]()
If it's properly installed, it should contain the fire inside the chimney and not start the house on fire. A bigger danger would probably be hot chunks of creosote landing on the roof.Jack Straw said:Just wondering: If you have a properly installed ss chimney, what are the chances your house burns down if you have a chimney fire?
atomichawg said:firefighterjake said:How to know if you are "having" a chimney fire: Typically you will hear it -- sounds like a freight train or Boeing 747 about to take off . . . another tell-tale sign that you're having a chimney fire is when the firefighters begin climbing on your roof.
I knew some one would have a smart aleck reply!![]()
cmonSTART said:Creosote also takes on a very light and airy texture like popcorn after a chimney fire. Very bubbly.
atomichawg said:So if you are having a chimney fire, call the fire department?
