Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I love top down. I started one like her first one in the video the other night using pieces of Super Cedar on top instead of the newspaper knots. It worked like a champ.
I think the overhand is the wrong kind of knot for newspaper. A bowline is a better knot with much greater breaking strength. If you want to join two or more rolls of newspaper, try the re-threaded figure eight or the double fisherman's, unless of course your rolls of newspaper that you are tying together differ significantly in diameter, in which case you might be better off with an Albright knot.
I tried top-down method last spring. I'm 2 for 2 this season. I stack the stove with big splits, then medium logs, twigs, some cardboard and newspaper on top. Light it and 40-45 minutes later I'm at 450F and climbing. Now it seems silly to try piling bigger logs on a little fire. That's upside down. Top down works great in my Vermont Castings Vigilant.
However... Not everyone has the best luck with top down starts. I tried it for awhile, my wife liked it and made some improvements that worked for her but eventually I went back to bottom up. I know the smoke issue is better associated with top down. Personal preference I guess.
I use a top-down method but don't use paper of any kind. I do believe it works best for me in the stove and also in the backyard firepit. Nothing like building up a cross-stacked pile of splits in the pit and lighting from the top then not having to add wood for several hours yet having a nice constant flame with little to no smoke. Amuses guests too who don't expect it to work as well as it does.
The idea is you fill the stove up and like Slow1 does criss cross if you can to have more space between splits for air flow.
But by filling the stove up about the only open space is up at the top to stack some kindling and fire starter (newspaper).
The kindling will burn hotter and faster being up there by the secondary air tubes feeding it fresh air and the small space thats left up there heats up really quick.
By not piling a bunch of wood on top of the kindling lets the kindling burn quicker and hotter.
Having a big open space in your stove by making a little pile of kindling on the bottom and stacking a couple big pieces on top makes for a lot of open space to heat up and that takes longer.
As the video says heat radiates in all directions so as the kindling on top burns the wood underneath gets heated for also, but now with the top down set up, the heat build up is faster and hotter and it radiating down to catch the splits below on fire. Its all about build heat. I say that as people usually think its all about a bunch of flames but you can have lots of flames and not build heat in the stove, so its all about the heat.
I loaded up some criss cross kindling and placed two square fire starters on the top and lit, I then noticed I had smoke coming out of the door and into the room, I knocked the fire starters to the bottom of the pile of kindling and It started up with no issue. What did I do wrong, door was cracked alittle and air was wide open?
During warm weather flues can be finicky with their draw. As its the difference in the temps as in outdoor temps verses temp of stove that creates the draw. I have trouble with my draw during mild weather. Some people have really tall chimneys with really good draw.
Each stove, fireplace insert hooked up to the chimney /flue seem to all have their own little characteristics.
You hear alot of times on here to give things time to learn your setup as they all are a little different.
Maybe people can post pictures of their top down fire starts.
Etiger2007, I am not sure what went on with your deal there, some people dont like top down starts and start their fires other ways , there is more than one way to do it. What ever works for you stick with it.
I would say but not sure but maybe if you too loosely stack your kindling and didnt have it ontop of some bigger stuff to fill up the stove. The object is to fill up the stove to reduce the amount of open air space in the stove to only leave a small space ontop of the bigger stuff to lay a small pile of kindling and fire starter. If you just used a pile of real loose criss crossed kindling ,I dont see that as filling the stove up like with bigger stuff to reduce all the open air space.
Next time if you could take a pic maybe we can get a better idea of maybe what happened. Top down works but with any stove from a cold start depending on how good of draw you have, a little smoke can try and escape out the door if you dont get the door shut quickly as its the heat that warms the flue and gets the draw going better. Its all about the heat.
(broken link removed to http://www.chiefchimney.com/fireplaces/upsidedown.pdf)
