I got the Buck Model 21 installed yesterday, but we need to shim the back of the stove by about a half inch because the firebox is a tad lower than the hearth.
I was thinking about using 2" x 2" x 1/4" thick square steel tubing, and cut it to 1/2" length and lay it on it's side and set the insert on it. (broken link removed) Will that work and support the weight and tolerate the heat?
Any other suggestions?
Thanks,
Scott
Thanks,
Scott
