Ok team - my Harman P43 is great and I‘ve read all the stickies in the forum about how to use the controls. I’ve also amused myself by reading way too many posts on this forum and I’ve got a new question for you. I’ve also watched a bunch of YouTube videos. Its cool how pellet stoves can be in modes that flex the heat up and down and I believe I’m understanding the basic mechanics of my stove. I’m also keeping my stove fairly clean thanks to all the input on this forum.
Here’s my question:
Lets say my house is cold or the outside temp has decreased dramatically. The stove is either off or at a low settIng. I’m cold! I want to manipulate my stove controls to enter “turbo mode” where I’m accessing the full heating potential of my stove for a period of time. In this scenario, for a little while, I’m not interested in saving pellets or being efficient - I want the max heat output per unit time! After my house is feeling more comfy, of course I’ll reset the controls to my nice room temp/stove cycling modes. (yes I understand that if I’ll keep it on and in those modes all the time then I won’t have to use turbo mode because the area will be at a more constant heat).
Now because I have read this forum way too much, I’ve seen a lot of posts where people make comments about “melting your stove” - ie - maxing things out and using multiple pounds per hour of fuel. That’s what I want! The max of everything!
So the question is - what combination of settings is “turbo mode”????
! Obviously increasing the left dial (either temp or 1-7) to max is a given. Would I have more rate of change in heat output if I briefly raised my feed rate dial ( from normal 3.5ish to much higher?). I assume increasing the distro fan to max only helps. Would I have a higher theoretical output in Room Temp or Stove Temp? I believe that if I’ll turn off the auto ignite to manual that might help too - that setting is a bit confusing since if the stove runs hard it won’t be entering maintnance burn.
I look forward to your answers!
Here’s my question:
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
