I am currently undergoing the installation of an EKO40 with 1,000 gallon storage (pressurized).
I have a Jacuzi hot tub with 350 gallons of water and am not quite sure how to hook this up to my exisiting hot tub (HX size, electrical connections, plumbing etc).
I currently use the 240 V, 5,500 Watt tube type heater that came with the hot tub and assume that there is a way to integrate the HX into this system while still using the temperature control of the hot tub itself to turn my circ motor on/off to maintain a 104 F max temp. (I am very comfortable working on the electrical system/circuit board on the hot tub).
Also, could it be installed so that I have the electric heater on the tub as a back-up (set to a lower temperature so as not to come on except when the water temp from the boiler gets to low).
Finally, since my hot tub is located approx. 10-15' from my storage tanks would it be practical to use a homemade copper tube HX installed inside my tanks (I realize I have to cut an opening in the tanks and then seal it very good to prevent leaking when under pressure-max 30 PSI) vs. purchasing a seperate plate type HX. I was also thinking about doing the same type HX installation in the tanks for solar collectors which I plan to install next year.
Can anyone help me with the proper sizing of the homemade HX that would be required for the hot tub and future solar collectors (I don't have an exact size/# of solar collectors I plan to use but the basic calculation(s) would be very helpful and greatly appreciated).
Thanks
Thanks
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
