Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
When you're pretty much down to coals like I am right now do you open up the air inlet control to give the fire max. oxygen? I'm thinking this will let it burn out without smoldering and giving off a lot of soot to dirty up the liner.
One or two shovel loads of snow should do it. If you need some, I've got it coming down over an inch an hour right now. 9" + right now, another 18" by Thurs.
Either or, Open it full up and let it burn out what it can, it wont contribute to any creosote. Or shut it down and let it die out and save the coals for the next time you start the fire.
When wood is in the charcoaling stage, it is my understanding that there's really nothing left in it that will contribute significantly to creosote formation. I seem to recall reading somewhere that the charcoaling stage is clean burning. Please correct me if I am wrong, guys. Thanks.
Depends what you want to do. If you want to burn the coals and extract the small amount of energy left in them before reloading pull the into the airstream (normally at the front of the stove) and give it maximum air. On the other hand if you want to save the coals for another fire later in the day just gather them up with all the ash into a pile in the centre of the firebox. To start the next fire (up to 24 hours later) just rake the coals forward, open up the air and they will be glowing orange in a matter of seconds. (Burying the coals in ash is kind of like pressing the pause button.)
If I have too many coals and want to make some room I open up the air to let them burn down a bit . . .otherwise I just let things run their course so I can get some hot coals for a later restart.
